Makes for a bad day when a valve and piston try to occupy same place at same time. Valve and head lost that battle. In a impact failure there tends to be fractured areas around hole. In pics you can see hole is much larger after weld prep- fracured stuff removed. Preheat at 350, weld hole and dings with a356, post heat 350, grind welds and machine for new seats, fab seats, pressure test, surface. Ready to race again.Peter Attached ImagesEquipment:2 old paws2 eyes (that don't look so good)1 bad back
Reply:one last pic Attached ImagesEquipment:2 old paws2 eyes (that don't look so good)1 bad back
Reply:outstanding work! i always love your threads!just curious, what does a repair like that cost?or, if you prefer, about what percentage of a replacement "race-prepped" head, such as this?
Reply:Awesome looking repair!! Not to sound simple but what is a 356? Did you use a filler piece or just start filling in the area..Really interested but I know almost nothing about it? Thanks DaleMiller 250DX HTP 221 DV AC/DCHenrob O-A Miller 180 MigMiller 150 Inverter Hobart 10,000 Welder-Generator Have a good day!!!
Reply:Very impressive work! You just saved the owner a ton of cash. Nice job!
Reply:I swear Peter, given a little time I'd bet you could build an entire head from filler rod.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by powerNot to sound simple but what is a 356?
Reply:Originally Posted by Meborderoutstanding work! i always love your threads!just curious, what does a repair like that cost?or, if you prefer, about what percentage of a replacement "race-prepped" head, such as this?
Reply:I like the signature, its like opening up a wall and seeing who built it, or who made a complete mess of things lol.I forgot how to change this.
Reply:You do great work for sure!!As said above I love to see your work.miller... 225g, s32p, 250x, 304, 12vs, MSW41 victor o/a thermal dynamics cutmaster 50 lenco panel spotter hobart hf-boxG3 Farms.....raising cattle, hay, kids and hell, ...oh yeah I'm a fire sprinkler contractor by trade.
Reply:have you fixed any other patriot heads? I know a guy locally that had a seat let go on him...tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:castweld - Great work, even greater patience.Same Time / Same Space = Interference, or Sucked a Valve.One cylinder damaged = SaV.In addition to the discrete, deep-damage welds, you 'weld dressed' the head plane surface, 'visually within' the cylinder head gasket imprint. Did you [have to] skim-plane the head?OpusLast edited by OPUS FERRO; 12-19-2012 at 01:54 AM.Reason: punc.
Reply:Nice repair Peter. +1 for the date and signature. Do you sign all your work or were you especially proud of this one? Maybe it's for warranty purposes?
Reply:Originally Posted by LawsonWeldingLLCI like the signature, its like opening up a wall and seeing who built it, or who made a complete mess of things lol.
Reply:What torch did you use for this repair ??Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Nice job! I would have thought that head was scrap. Would have never thought it was repairable."The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
Reply:Peter, A truly excellent salvage repair, Not many folks would tackle a job like that and have it end up being as good as new, You really are a very confident and competent tradesman in every respect,Lincoln SP-170 MigHypertherm powermax 45Lorch T220 AC/DC TigButters FM 215 synergic MigKemppi 180 adaptive mig RULES ARE FOR THE OBEDIENCE OF FOOLS AND THE GUIDANCE OF WISE MEN.
Reply:What do you think of the Patriot stuff as far as quality goes? Does the Aluminum seem to be on par with other Aftermarket Aluminum head manufacturers, Brodix,AFR,Dart......?
Reply:That is masterful work, VERY nicely done good sir.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Excellant job from a honest shop...great workmanship!!!
Reply:Originally Posted by DemonSpeederWhat torch did you use for this repair ??
Reply:Peter, we will send you more, again great doing business with a honest person like you. |
