Sureweld by national cylinder
发表于 2021-8-31 23:10:30 | 显示全部楼层 |阅读模式
Hey guys new to the forum.  I just aquired an old sureweld source machine and tig box. I was wondering if anybody knew anything about these machines. This thing is a single phase monster. I don't have any experience with tig. So I'm just Gona go through it slowly and try to get the source machine  working first. Here is a pic of the tig box[/IMG]
Reply:A lot of sureweld stuff was rebranded stuff from other big welding companies....  I don't recognize that on in yr pic.   Sure someone will but they are usually pretty reliable.  Check all the power supply connections that they are tight and correct connection before hooking them up.  Sent from my SPH-D700 using Tapatalk 2Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Originally Posted by soutthpawA lot of sureweld stuff was rebranded stuff from other big welding companies....  I don't recognize that on in yr pic.   Sure someone will but they are usually pretty reliable.  Check all the power supply connections that they are tight and correct connection before hooking them up.  Sent from my SPH-D700 using Tapatalk 2
GMT+8, 2025-12-28 02:13 , Processed in 0.235236 second(s), 18 queries .
