Welding and water
发表于 2021-8-31 23:10:29 | 显示全部楼层 |阅读模式
Hi All - I just spent about 2 hours welding a stainless steel tank that was leaking - All of 10 cm ( 4 inches). The tank normally contains methylated spirit. It was flushed a couple of times with water and purged. The area where it leaked held a small amount of water that I could not get out. So I welded a wet seam. The only way I could do it was form a puddle on a dry area and then migrate to the wet seam and kinda drive the water in front of the puddle out of the seam. Its a pain in the behind as the arc is unstable.  If I have to do something like that again I would like to know if any of you have a better way of welding a wet seam. I was using tig as the tank is thin walled. The welding was done upside down and stainless steel stick welding was not really an option due to the thin wall of the tank - I was worried about blowing a hole and creating more problems. Nonetheless,would spot welding with stick work in this scenario? Thanks for any input.
Reply:a lil preheat to dry "it"the joint out ???Miller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:The section of tank held too much to preheat. Wet joints are not really a prob lem as the welding process itself generally pre-heats enough to drive resident moisture out. I am talking about the situation where the joint leak has a constant supply of water. The tank in question is part of a structure and cannot be removed.
Reply:Thanks for the seedy response. The section of tank held too much water to preheat and evaporate. Wet joints are not really a problem as the welding process itself generally pre-heats enough to drive resident moisture out. I am talking about the situation where the joint leak has a constant supply of water. The tank in question is part of a structure and cannot be removed and as always the customer is hopping up and down and shouting about production. I have a very good relationship with the customer and I got the job done. I was just wondering if there is a faster way of doing it next time round
Reply:Could you use a piece of bread? The bread soaks up the xcess water and purges when you refill with methylated spirit. Just a thought.
Reply:Thanks for the bread idea. I was thinking of putty or some similar substance, but in the past when I tig welded into putty the results were not pretty. I never thought of bread and I will try it next time. I find that as long as I can get a dry spot for a second or two I can start the puddle and get going. Mayhaps bread will do it. Thanks again
Reply:Close up all the openings but one (not counting the seam being welded) and apply a vacuum to it. Entering air or TIG gas will 'blow' the water away from the inside of the joint somewhat, depending on the degree of leakage. A shop vacuum should work OK.If you could put a strong vacuum on (as from a good, high capacity vacuum pump), it would allow the water to boil at a much lower temperature and with less preheat. That, together with the leakage, should do some good. Just don't collapse the tank; if it's thin, this isn't safe with either vac. source.
Reply:Originally Posted by Odd Job WeldingThanks for the bread idea. I was thinking of putty or some similar substance, but in the past when I tig welded into putty the results were not pretty. I never thought of bread and I will try it next time. I find that as long as I can get a dry spot for a second or two I can start the puddle and get going. Mayhaps bread will do it. Thanks again
Reply:A strong high capacity vacuum pump could also collapse the tank like a beer can under a fat mans foot.   I had to watch a training safety video where they collapsed a rail car with a fairly insignificant amount of vacuumVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:X2 on the vacuum warning.Seen the railcar thing first hand.Guy  starts to unload car with vacuum hose at bottom and forgets to open hatch at top.Miller a/c-d/c Thunderbolt XLMillermatic 180 Purox O/ASmith Littletorch O/AHobart Champion Elite
Reply:Vacuum or laminar flow would distrupt gas flow(Argon,CO2, He. Xe Ne,etc)Wouldnt it? Nev er mind
Reply:Originally Posted by InsanerideVacuum or laminar flow would distrupt gas flow(Argon,CO2, He. Xe Ne,etc)Wouldnt it? Nev er mind
Reply:My original idea for evacuating a vessel of some type is; use air vacuum whatever to get the bulk, then, pour in 90% alchohol, then ignite it. Stand back for safety officials. Then use bread or the safe chemical the local plumber supply carries. Then: shut up and weld!
Reply:OK BYE  Angel Larry)
Reply:Without seeing a picture, it's a tough call, but I've had similar fiascos with Stainless and Aluminum. Sometimes I drilled a tiny (1/16th) or so hole at the lowest point, did the repairs, then welded up the hole I drilled. Purging the inside with a constant flow of argon might be helpful.Dougspair
GMT+8, 2025-12-28 04:12 , Processed in 0.225230 second(s), 18 queries .
