Can I use this Regulator?
发表于 2021-8-31 23:10:28 | 显示全部楼层 |阅读模式
I found a Victor SR600 oxy regulator for $95 brand new (these retail for like $450-$500).  My question is.... could I... or should I use this for replacing my very old oxy reg(SR200).  I was going to send the old regs in for rebuild....  when I found this.Here are the specs for the SR600. Are the outlet pressure ranges too high for practical use on an oxyfuel rig?? The delivery ranges look good at 5-550 PSIG. If I used this on the oxy side..... could I still use say a 450 on the fuel side? Would I need a special hose to handle the outlet pressure of 350/550 PSIG of the SR600?It looks like I will need to change the outlet to 9/16"???? Let me know your thoughts. ThanksSR 600Heavy DutySingle stage regulator designedfor pressure testing and idealwhere 350 or 550 PSIG(maximum) deliverypressures are needed, suchas dead-end testingDESIGN/CONSTRUCTION• Forged brass body &housing cap• 2.5" (63.5 mm) gauges – brass(6000 lb. high pressure, 600 lb.and 1000 lb. low pressure)• Cartridge type seat assembly with PCTFE seat• Diaphragm -–stainless steel• External self-reseating relief valve• CGA 540, 580, 346 have a maximum inlet pressure of 3000 PSIGDimensions7.5" W x 6" H x 5" D(190.5 mm x 152.4 mm x 127.0 mm)Weight5 lb. 7 oz. (2.47 kg)PERFORMANCEMaximum inlet – 5500 PSIGOutlet pressure ranges – 350 and 550 PSIGInlet port – 5/8"-20 UNF(M)Outlet fitting – 1/4" Swagelok-brassTemperature operating range – 0-140°Delivery Range: 5-550(PSIG)Oxygen 0781-1610 SR 600-550-540 5-550Last edited by cybordolphin; 06-18-2012 at 11:52 PM.
Reply:cybordolphin  -  Your answer is within your question.  Opus
Reply:There's like 4 questions above.  Which one holds the answer you speak of?  Lets keep it simple.  Will this reg work for MY intended purpose?Last edited by cybordolphin; 06-19-2012 at 03:25 AM.
Reply:cybordolphin  -  Dwell.   Opus
Reply:Thanks for the philosophical approach.  I failed that course though.  Anyway.... any elaborated response is greatly appreciated.  It would appear the reg will work... albeit the need to be cautious to not over adjust the reg to overpressure the hose.  Or perhaps make sure the hose is rated accordingly. I have limited experience using an oxyfuel setup.... so appreciate some wisdom (short of the Yoda thing).Thanks
Reply:I think you'd be nuts to use that regulator. One wrong turn and you'll have a couple hundred PSI in your torch by mistake. I can't see a happy ending there.Miller Multimatic 255
Reply:Thanks.....   I am going to just have my old regs rebuilt (I was quoted $45 each).
GMT+8, 2025-12-28 02:13 , Processed in 0.174891 second(s), 18 queries .
