Cheapest source for Electric motors???
发表于 2021-8-31 23:10:19 | 显示全部楼层 |阅读模式
Looking for a replacement 1hp motor formy table saw. 3450 RPM 115/230 56 Frame. Tried grainger and surplus center.Where else?
Reply:Tractor supply, or Harbor Freight
Reply:Harbor Freights store was useless, I'll check the website
Reply:http://www.surpluscenter.com/sort.as...ch=table%20sawneither of those work??StangnetShop Full Of Stuff. Joey
Reply:Is it totally fried??If not you should be able to fix it.Normally the starter capacitor dies. (underneath the humpon the frame) or the centrifugal switch inside getsstuck. I fixed many of them in the past few years...http://www.northerntool.com I saw one there also.
Reply:Before you get too down on the old one, take an airhose and blow out the starter switch.  One of mine quit a few years back & it was just sawdust in the contactors of a 50+ year old motor.
Reply:Banzai,You don't say what saw you have, but if it's a belt drive saw, I'd think about going to a 1-1/2 hp motor if your repair efforts fail.  One horse is kinda light for a 10" saw, but maybe you ain't got that!!Be well.hankj
Reply:i just found www.globalspec.com it says they have motorsStangnetShop Full Of Stuff. Joey
GMT+8, 2025-12-28 04:12 , Processed in 0.222997 second(s), 18 queries .
