How close is too close?
发表于 2021-8-31 23:10:08 | 显示全部楼层 |阅读模式
So today after school, I noticed my hood has alot of spatter marks... guess I'm getting close enough to see the work...Sent from my SAMSUNG-SGH-I337 using Tapatalk
Reply:I usually get about ten to fourteen inches away sometimes further sometimes closer that's just a usual for me.Ranger 250 thick stuffHobart Handler 140 not thick stuffthe pane and oxy setup
Reply:Depends what kinda work. Is it tig or stick? Haha the white will show every speck of dirt. I always try and maintain the best posture possible. So I'm and where from a foot to 2 feet away from my weld.Sent from my iPhone using Tapatalkif you can step across it I can weld it.
Reply:Recheck if your lens is too dark.Also see an opthamologist. You could be nearsighted, like me.Be wary of The Numbers: Figures don't lie,. but liars can figure.Welders:2008 Lincoln 140 GMAW&FCAW2012 HF 165 'toy' GTAW&SMAW1970's Cobbled together O/A
Reply:Right now we are doing mig, but we did 6 weeks of stick before.Mike, using a shade 10 auto dark. And im def near sighted, have been since 2nd grade....Sent from my SAMSUNG-SGH-I337 using Tapatalk
Reply:Try a cheater lens, see if that helps.
Reply:I also use a set of prescription safety glasses. For grinding and whatnot they are the worst... Helps with my depth perception since one eye is weak and one is overly strong. And make sure you use the right shade for the right process and power output.Sent from my iPhone using Tapatalkif you can step across it I can weld it.
Reply:I've melted holes in clear lens....250amps, 8in away.I was wondering what that thing was coming from....
Reply:If you wear glasses, talk to your eye care pro to set you up with glasses that will allow you to see clearly at 12 to 14 inches. Less than 6" will melt your headgear.Be wary of The Numbers: Figures don't lie,. but liars can figure.Welders:2008 Lincoln 140 GMAW&FCAW2012 HF 165 'toy' GTAW&SMAW1970's Cobbled together O/A
Reply:Right now we are on mig/flux so with the 35 solid wire, i'm running 18.5v/250ipm wirespeed. my ad lens (#10) doesn't seem to  be too dark, as i can see about 1/4" infront of the puddle.
Reply:Originally Posted by mike837goIf you wear glasses, talk to your eye care pro to set you up with glasses that will allow you to see clearly at 12 to 14 inches. Less than 6" will melt your headgear.
Reply:God forbid you should get a few burn marks on your WELDING HOOD!I get a kick out of those guys that TIG about an inch from their lens. I like to go up and push their head back, that really messes them up.
Reply:Originally Posted by TimmyTIGGod forbid you should get a few burn marks on your WELDING HOOD!
GMT+8, 2025-12-28 04:01 , Processed in 0.096621 second(s), 18 queries .
