Overkill cart
发表于 2021-8-31 23:10:02 | 显示全部楼层 |阅读模式
Thought I'd post a few pics of my welding cart.  It was the first thing I built with my new Eastwood 175 (my first mig).  It is designed to hold both my welders, and two large cylinders, one for my CO2/argon mix and the other for straight argon, for welding aluminum.  Eventually, when I get the $$$$$$, I would like to take the Lincoln off and put a plasma cutter in its place.  Space is tight in my garage, so I wanted to fit as much as I could on the cart, and also have helmets, clamps, mig pliers, grinders all at arms' reach.  I have used it now on 3 different projects and am loving it.
Reply:I think my cart deserves your thread title. Attached ImagesTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Damn,Now THAT's a cart!Buy American, or don't whine when you end up on the bread line.
Reply:Do you think this cooler make my carts Azz look fat?
Reply:Southpaw i thing somethings missing but i just can't tell what
Reply:Originally Posted by a1998z3Southpaw i thing somethings missing but i just can't tell what
Reply:Originally Posted by 7A749 ... My only suggestion would be to replace the rear wheels with Phenolic ones...
Reply:Originally Posted by Fabn4Funx2 - ask me how I know!  Looks like Southpaw "went all the way" with cast iron!
Reply:Originally Posted by soutthpawthe wheel set is actually the miller oem wheel option for the 330abp and dialarcs, etc.  Has spring loaded handle too
Reply:Nice "save" with the plywood sides on the plastic spool..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by DSWNice "save" with the plywood sides on the plastic spool.
Reply:Look at the lower part of the spool on the far side just above the gun cable. Looks like the black plastic rim is broken, possibly form someone mishandling the spool. Usually we just toss the spools when that happens. I'm thinking he managed to "save" the spool by doing that..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by DSWLook at the lower part of the spool on the far side just above the gun cable. Looks like the black plastic rim is broken, possibly form someone mishandling the spool. Usually we just toss the spools when that happens. I'm thinking he managed to "save" the spool by doing that.
Reply:Originally Posted by SeanMurphy265It's missing a mini fridge and micro wave oven!  I think I saw where Snap On or someone was putting mini-fridges in tool boxes.
Reply:Originally Posted by soutthpawI think my cart deserves your thread title.
Reply:Originally Posted by frieedneeds Jethro driving and granny on top in her rocker...
Reply:Originally Posted by 7A749You run that off a rotary converter or do that dudes conversion on it?If you got 3 phase at your house, I don't even wanna know......When we move, I'm gonna find some farm property with 460 at the pole.One day.........
Reply:Originally Posted by Fabn4FunNo 3ph ... no shop ... not even a garage yet!  Rotary converter 20hp with a 1hp "pony" motor to start it.  Will post it as a project someday soon ...The laugh of the day is that it would like to have a 125A breaker ... it's on a 50A, and the whole house panel is only 100A!  That means it never gets turned up very high!   .
Reply:i too once built the obligatory rolling carryall..but i found that since i work froma very crowded garage, not a nice shop, i never ever roll it around..it serves as a welder and commonly-used handtool storage, but i found longer leads was the answer for me.. Attached Images
GMT+8, 2025-12-28 02:12 , Processed in 0.121084 second(s), 18 queries .
