sa200 fan shroud and fuel tank
发表于 2021-8-31 23:10:00 | 显示全部楼层 |阅读模式
I thought I'd post a few pics of a couple of things I've fabbed for my sa200 project. It's all made out of .080 3003 aluminum. Attached Images
Reply:Heres a few pics of the gas tank. Attached Images
Reply:Awesome!  How many gallons will the tank hold?  It looks bigger than the original.
Reply:It's a little bigger but not much. I probably could've gone alittle bigger but thought I'd stay close to original. I will probably never be running tank after tank of fuel through this thing like some true pipeliners so I'll never know the difference.
Reply:Nice job ShowdogMiller Syncrowave 350Millermatic 252/ 30A spoolgunMiller Bobcat 225g w/ 3545 spoolgunLincoln PowerArc4000Lincoln 175 Mig  Lincoln 135 Mig Everlast 250EX TigCentury ac/dc 230 amp stickVictor O/AHypertherm 1000 plasma
Reply:Can you send some dimentions of the shroud basically how big of a hole did you cut
GMT+8, 2025-12-28 04:01 , Processed in 0.246448 second(s), 18 queries .
