where can I buy weldable Aluminum hinge that is detachable?
发表于 2021-8-31 23:09:55 | 显示全部楼层 |阅读模式
where can I find weldable hinge like the one in the photo? i think they are calledWeld-On Lift-Off Hingesthe studded aluminum panel's hinge can be removed by simply lifing upwards.i found these but they are quite different looking though they are similarhttp://www.mcmaster.com/#weld-on-hinges/=ksgkaohttp://www.mcmaster.com/#weld-on-hinges/=ksgl8nthanks for any helpthe reason I like the hinge in the photo is it is rather big so it si easy to attatch a big bulky 2x4' door using these hinges. The hinges from mcmaster have tigher tolerances and they are not as "user friendly" I'm thinking any lift off hinge with around a 1/4 to 1/2 diameter pin would work.Last edited by AluminumWelder; 12-28-2012 at 12:17 PM.
Reply:Google is amazing. Welding Web is not google. Alternately, the design in your photo looks extremely easy to make. You should try.Lincoln Precision Tig 185Lincoln Power Mig 256Hypertherm PM 45Everlast 140STSmith O/A
Reply:the labor to make such a hinge would obviously far out cost what it would be to buy it. and I did google it without luck.
Reply:Originally Posted by manningGoogle is amazing. Welding Web is not google. Alternately, the design in your photo looks extremely easy to make. You should try.
Reply:Clarify if u need this in steel or aluminumTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Prefer aluminum, but will take steel if that is all that is available. If I get AL I can weld it. If I get steel I'll have to bolt it.
Reply:I'm sorry... but what you have pictured is very easy to make... unless you were to buy a large amount of them at once, but then you still have added expense of shipping... I would make them...Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:might be obvious but have you contacted the manufacturer, might just send you a couple of hinges for a price or direct you to a source."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Try Fastenal.  They have aluminum hinges like that, in stock.
Reply:Thanks but after looking for half hr couldn't find any at fastenalGot a direct link?
Reply:Originally Posted by AluminumWelderThanks but after looking for half hr couldn't find any at fastenalGot a direct link?
Reply:I would check McMaster or Grainger or maybe a industrial supplier for doors-cabnets maybe?Miller 250DX HTP 221 DV AC/DCHenrob O-A Miller 180 MigMiller 150 Inverter   Hobart 10,000 Welder-Generator   Have a good day!!!
Reply:Would these work?  They are called slip joint hinges.http://customhinges.velko.com/viewit...-joint-hinges?
Reply:Or these on the Fastenal site.http://www.fastenal.com/web/products...ex?sku=0961554
Reply:@power & @comp chasis. thanks for the help. the issue with those things is they require pretty precise alighnment. I'll probably just get some and drill them out a bit so they are more user friendly. Taking 1/2 hr to make a $5 hinge as others have suggested is not really economical. Besides I don't have the machine/tools to cut out a nice round edge like the original photo shows.
Reply:Originally Posted by AluminumWelder@power & @comp chasis. thanks for the help. the issue with those things is they require pretty precise alighnment. I'll probably just get some and drill them out a bit so they are more user friendly. Taking 1/2 hr to make a $5 hinge as others have suggested is not really economical. Besides I don't have the machine/tools to cut out a nice round edge like the original photo shows.
Reply:Those look  like hinges the people who build those photobooths  came up with for there booths and probably made in house or had a large amount made for them since your trying to copy them you'll probably have to do the same350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:Nope not copying the design and I'm coming up with something better.  the main structure is OK, but the electronics, especially how they have a printer rigged up is just a bad design. Ordered 4 different Mcmastercarr.com hinges. Nice thing is they ship out of Atlanta which is one day shipping via UPS to me.  I would be interested in learning how they made those hinges though? Were they stamped out by a stamping company with a metal die and then bent? Were they cut by hand individually. the round part looks very uniform, so I'm guessing a stamping company, but I'm not much of a machinest, so there's probably something I'm missing.Last edited by AluminumWelder; 12-30-2012 at 03:49 PM.
Reply:http://www.austinhardware.com/index.cfmTry Austin Hardware, I did not look, but they have alot of hardware.
Reply:you can get those fastenal hinges (actaully they are 80/20 hinges)from ebay for $6 a set vs $17 a sethttp://www.ebay.com/itm/80-20-Inc-15...item337a830129hope that helps.
GMT+8, 2025-12-28 04:01 , Processed in 0.076711 second(s), 18 queries .
