I've got a new Lincoln 256 powermig. Works great, but the ground wire is too short. I've got an additional 8 feet of the same wire (#2/0) and want to join these 2 wires, then add the clamp onto the new end. I don't want or need to be able to separate the joint. Is there a connector to do this I can get? I have seen lots of lug style but don't really want to use that. How should this be done?
Reply:There are various kinds of cable splicer sleeves - crimp-on, hammer-on and bolt-on.http://www.weldingcable.us/LENCO-Cab...-AWG_p_42.html"USMCPOP" First-born son: KIA Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:i normally use a piece of copper or brass tubing cut it at about 1.5 inches long drill a 1/8 hole in the middle heat it insert the bare cable ends and fill with solder let cool and heat shrink (the heavy duty one with the sealer in it ) or rubber splicing tapeLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:What ever you use, I would solder it like AW said.
Reply:Yep, what AW & Bob sezd. I would put at least 2 layers of shrink for wear, maybe 3. You going to drag that thing around for a few years, no? I hate redoing a job down the road, I'm just lazy, I guess, When a welder tells you to "stick it", what do they really mean?"In a time of universal deceit, telling the truth is a revolutionary act." - George Orwell
Reply:Originally Posted by bearstonYep, what AW & Bob sezd. I would put at least 2 layers of shrink for wear, maybe 3. You going to drag that thing around for a few years, no? I hate redoing a job down the road, I'm just lazy, I guess,
Reply:http://store.cyberweld.com/diiwecacofe5.htmlBuy a male two. They come in different cable/amp sizes,Not what you said what you wanted or needed, but really handy..I use them on many machines, and can change styles of ground clamps as needed Attached ImagesEsab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:this has worked for me Attached Images |
