Hey Florida Jim, I have a mod for your mill/drill
发表于 2021-8-31 23:09:41 | 显示全部楼层 |阅读模式
And it works. Attached Images
Reply:What is it??
Reply:Looks like it's grey and red.  Could be a hydraulic head lift?  Maybe it even keeps the head aligned when moving it?
Reply:Naw, it is blue and red. It does keep the head from rotating when you raise and lower it.   Attached Images
Reply:mike, what does the base of your alignment rod look like ? is it attached the base of the mill or the table, surely it's the base.
Reply:Under the table top is 3" channel that the mill is bolted to. The pipe is welded to 1/2" plate that is bolted to the channel so it is pretty stiff.
GMT+8, 2025-12-28 02:13 , Processed in 0.126275 second(s), 18 queries .
