hobart fabricator
发表于 2021-8-31 23:09:36 | 显示全部楼层 |阅读模式
Has anyone had experience with the hobart fabricator? Little bit older machine but made for heavy welding. I just purchased one and thought I'd see if anyone knows much about them
Reply:Do you have a picture of it???Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Sent from my SM-N900V using Tapatalk
Reply:Originally Posted by AKweldshopDo you have a picture of it???
Reply:My hunch is that as long as it works your fine but if your were to need parts your sunk. That was made before Hobart was split up and I suspect that line of equipment was taken over by Thermadyne and as such not well supported.
Reply:I was able to aquire a owners manual from miller welders. It's a basic transformer box. No real circuitry insideSent from my SM-N900V using Tapatalk
Reply:Looks like a tweco gun. Easy parts for that.Does it work good???
Reply:Yeah it works wonders. 60% duty cycle @ 300amps Sent from my SM-N900V using Tapatalk
Reply:i like it alotttt. It looks like it has about 40 voltage taps. The feeder looks like an ancestor of the miller 22A kinda. Give us a picture of the wire feed rolls. That's a nice little droid you have ther Attached Images        thermal arc 252i  -  millermatic 350P -   miller XMT, cp300ts, 30a 22a feeders, buttload of other millers, handfull of lincolns, couple of esabs  -   Hypertherm 1250 G3
Reply:I can get a few more pictures once I'm home. I'll Crack open the top and show you all the insides of it. Looks like a octopus.  You correct. It goes up to 40 volts  I believe it goes up to 400 amps on the top Guage. I bought it from a guy who welded loader buckets with it . Made in 1990Sent from my SM-N900V using Tapatalk
Reply:I'm glad for you it sounds like I'm all wet
GMT+8, 2025-12-28 04:01 , Processed in 0.256450 second(s), 18 queries .
