Help me find thread
发表于 2021-8-31 23:09:31 | 显示全部楼层 |阅读模式
A week or two ago I was reading a trailer thread and somebody was explaining the reasons slipper springs were better than a shackle style setup for tandem trailers. Had to do with axle alignment and tire wear. I have tried searching for all the related terms and discovered there are a lot of trailer threads here. Can anyone point me in the right direction?Lincolin Power Wave 450, Lincoln Powermig 255, Lincoln Pro Mig 140, Lincoln Squarewave Tig 275, Miller Big 40 G(with Hobart Hefty suitcase), Thermal Arc 95S and Esab PCM875 in an already full machine shop.
Reply:Is this the one you were thinking of? I believe what you described was mentioned in this thread somewhere.http://weldingweb.com/vbb/showthread.php...latbed-Trailer
Reply:Nope not that one.Lincolin Power Wave 450, Lincoln Powermig 255, Lincoln Pro Mig 140, Lincoln Squarewave Tig 275, Miller Big 40 G(with Hobart Hefty suitcase), Thermal Arc 95S and Esab PCM875 in an already full machine shop.
Reply:http://weldingweb.com/vbb/showthread.php...41#post4123941post #13This needs to be a stickyBlackbird
Reply:Originally Posted by dave powelsonhttp://weldingweb.com/vbb/showthread.php...41#post4123941post #13This needs to be a sticky
Reply:http://weldingweb.com/vbb/showthread.php...41#post4123941post #13This needs to be a sticky Originally Posted by zapsterAnd why is that?...zap!
Reply:To be honest, they're all about the same..........they all wear outI have slipper type suspensions anchored by a bolt through the leading edge of the springs, AND THEY WEAR OUT THE SLIPPER PADS.I have full floating slipper type suspensions (Hutch/Reyco semi suspensions), AND THEY WEAR OUT THE SLIPPER PADS, AND SPRING LEAVES,NOT TO MENTION TORQUE ARM BUSHINGSTorsion systems sag over timeAir bag systems either rust out in the trailing arms, or the bags go badBottom line........suspensions wear because they absorb all the shock (big shrug)"Any day above ground is a good day"http://www.farmersamm.com/
Reply:It really boils down to matching the suspension with the anticipated load.Heavier isn't necessarily better either  Heavy duty suspension will beat itself to death if under loaded.Empty miles wear suspensions just as much, if not more than loaded miles.  The slapping is murder when running empty.  Actually I'd go out on a limb, and say that empty miles are the WORST"Any day above ground is a good day"http://www.farmersamm.com/
GMT+8, 2025-12-28 06:04 , Processed in 0.271389 second(s), 18 queries .
