Help!!Question bidding!!
发表于 2021-8-31 23:09:29 | 显示全部楼层 |阅读模式
I need to bid my first job working for my self.Its gonna be a 8 foot long C that goes over a beam(4x6) .Need to use 3/8 and make a big piece on channel with holes in it to through bolt and two brackets to hold 4x4s I was thinking 600$ installed and he gets hard wear and metal ????Im I too high???Thanks Guys!!!!
Reply:No offense, but being able to quote, would be the first thing I'd make sure I'd have correct before going onto my own endeavors...
Reply:Yea Im jumping in head first!!!I have welded for others as a job but got my equipment set up and took a job little too soon but its only a giant Simson hanger.I can make it no problem just wanted to know if my price is high or low .16 feet of weld and some cutting ,ill learn to bid as I go but need to start somewhere!(don't worry I didn't quit my day job)   Thanks   Steve
Reply:A good place to start is if it's on-site, $1/mile there and back, material cost x 1.5, then $1-$2 per hole depending on size, and estimate how long it will take you (plus 10-20%) and find a good hourly rate for that estimate (at least $40/hr), then add some. You say you've welded before so you should be able to come up with a pretty good estimate for time. Don't sell yourself cheap. Remember, the time you spend driving there is time you could be spending doing work for someone else, so why should you quote any less for the drive time as you would to weld?John 3:16(2) Miller Pheonix 456(2) Millermertic 252Dynasty 210DXHobart 210MVPDoringer D350 SA Cold SawScotchman 350LT Cold SawWebb 10x50 MillWebb 15x40 LatheGeka Bendicrop Ironworker
Reply:Thanks! !!Hope my Hobart 210 will Buzz the 3/8 I usually just use quarter inch but I'm gonna test some out tomorrow before I shake hands!Thanks again buddy! !!-
Reply:Job went smooth !!Thanks guys
GMT+8, 2025-12-28 04:12 , Processed in 0.072334 second(s), 18 queries .
