flowmeter on suitcase
发表于 2021-8-31 23:09:16 | 显示全部楼层 |阅读模式
Anyone ever run a flowmeter on the suitcase for long distances? I come across a job where im running 75 feet of argon hose and it would make sense to me to run a double regulator. Reason being would be for the fact of the initial purge of gas that it takes to fill the volume of the hose. Maybe im just thinking to hard? Anyone have an input I would appreciate it. I figured I would run maybe 50 lbs of pressure from the tank to the suitcase in order to keep that push, then run whatever I want to the actual gun.
Reply:i run 75' to 100' every day never had a problem i run 15-20. for dual shield im around 45. i only run a regulator on tank.Last edited by grindel; 06-25-2012 at 09:27 PM.Miller Pro 300 SS w/ cat Miller Bobcat 250Miller Diversion 165 Miller 211Miller Xtreme 375Miller 12vsMiller Dynasty 200 DX Miller Passport Plus w/ Spool GunMiller 30a spoolmaticLincoln AC225 Buzz Box VictorMathey Dearman - H&M
Reply:thanks a bunch. I bought two lengths for now. A 25 footer with quick disconnects and a 50 footer with quick disconnects, that way I only use what I need and then add more if I need it.Appreciate the reply, Greg
Reply:I regularly run 200+ feet of hose with no problems only using the flowmeter on the tank, just hit the purge button a couple of times when you string out, no worries.6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
Reply:beauty. thank you all for your expertise advice. expat i've been doing a lot of heavy equipment repair, but nothing to your caliper. I really want to buy a plane ticket to ghana to work on that gold mining equipment. I hear from locals that some of those guys in ghana that run the machines all day hire americans. They pay there way and even a place to crash there. Sometimes giving them 1500 us a week. Maybe this is bs?
Reply:Originally Posted by lovetoweldbeauty. thank you all for your expertise advice. expat i've been doing a lot of heavy equipment repair, but nothing to your caliper. I really want to buy a plane ticket to ghana to work on that gold mining equipment. I hear from locals that some of those guys in ghana that run the machines all day hire americans. They pay there way and even a place to crash there. Sometimes giving them 1500 us a week. Maybe this is bs?
Reply:I worked in a shop where we had really long argon hoses on the welders and every welder had a flow regulator on the feeder. It was kind of handy actually.
Reply:Hello lovetoweld, I am a little bit late on this, yet, the newer LN 25's use exactly that sort of set-up incorporated into their cases. Helps to prevent the "puff" that can be experienced when you trigger the gun. Think of this in terms of how a garden hose reacts. When the hose is turned on it flows water out of the end of it at a given rate. If you put your thumb over the end and stop the flow of water for a moment or two and then take your finger off you will initially notice an increase in flow from the built up pressure. With a flowmeter or regulator located at the tank and a long run of hose you can experience a similar sort of thing. Having the flowmeter located at the suitcase will limit this effect. It's kind of splitting hairs in some cases, yet for some this appears to be important and worth addressing.Good luck and best regards, Allanaevald
Reply:For shielding gas, I just use a 50' regular 1/4" rubber air hose with Milton fittings. Harbor Freight sells the Goodyear ones cheap. Much cheaper than getting a special argon hose."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
GMT+8, 2025-12-28 04:03 , Processed in 0.095035 second(s), 18 queries .
