Van Norman Brake lathe question
发表于 2021-8-31 23:09:08 | 显示全部楼层 |阅读模式
On a model 333, the spindle reduces down to 1" where a brake drum is clamped. The other end has a large nut. I took it off and it is a shaft that unscrews from the other end.I thought the 1" end woud have a taper that the threads would pull tight. I am trying to remove the 1" part but I can't get it to budge. The 1" end is larger where it goes inside the spindle. Any ideas? Thanks
Reply:Do you have a picture you could post?Ron ShopFloorTalk Millermatic 350P, M-25, M-40 gunsDynasty 300DX, Coolmate 3, Crafter CS-310 TorchTrailblazer 302, 12RC, WC-2430A spoolgunSpectrum 2050Thermal Arc Plasma Welder PS-3000/WC-100B
Reply:Sure, I will have to do it tommorrow.
Reply:Here is a pic of the spindle standing on one end. http://img36.photobucket.com/albums/...t=DSC00290.jpg
Reply:Looks like another job for Cutter.
Reply:left handed threads??????
Reply:I am thinking that it should be a taper fit. I have it soaking in PB Blaster right now.
GMT+8, 2025-12-28 04:11 , Processed in 0.191299 second(s), 18 queries .
