benders
发表于 2021-8-31 23:09:07 | 显示全部楼层 |阅读模式
what can one of the hf benders do with 2" pipe, i'm assuming nothing.........StangnetShop Full Of Stuff. Joey
Reply:i don't need it to do a 90' bend, just a series of small gradual bends equaling a radius, i'll post a pic of my exampleStangnetShop Full Of Stuff. Joey
Reply:this isn't to any scale, the circles are holes where a pipe goes through it.... complicated huh?? Attached ImagesStangnetShop Full Of Stuff. Joey
Reply:bumped up.............StangnetShop Full Of Stuff. Joey
Reply:So you are looking to build a downtube for a frame that is similar to the cromed out sturgis special Jesse James made on Motorcycle mania 2?  Why don;t you just build a jig, heat and bend like he does?
Reply:you hit it right on the head, except i'm going flat black,  i don't have a torch set so thats why i was looking towards a cheap bender.   any help appreciated!!StangnetShop Full Of Stuff. Joey
Reply:you think 1/8'' wall 2'' o.d tube is too big?StangnetShop Full Of Stuff. Joey
GMT+8, 2025-12-28 04:05 , Processed in 0.339427 second(s), 18 queries .
