Drill Press Woes
发表于 2021-8-31 23:09:03 | 显示全部楼层 |阅读模式
Fired up my lil Homier Drill press tonight for the first time and the dang drill chuck dropped one of the jaws. I think I can fix it if I can get the chuck itself back off. It is just a press on fit type of chuck. Any ideas on removing this? Thanks in advance.
Reply:Typically chucks are held on with a Jacobs taper.  Two wedges are used to remove the chuck.  I will see if I can find a place you can buy them.  I could send you a drawing so you can make your own.  Let me know what your email is.Ron ShopFloorTalk Millermatic 350P, M-25, M-40 gunsDynasty 300DX, Coolmate 3, Crafter CS-310 TorchTrailblazer 302, 12RC, WC-2430A spoolgunSpectrum 2050Thermal Arc Plasma Welder PS-3000/WC-100B
Reply:I have a ball joint pickle fork...would that work?
Reply:It likely could I'd try it.Ron ShopFloorTalk Millermatic 350P, M-25, M-40 gunsDynasty 300DX, Coolmate 3, Crafter CS-310 TorchTrailblazer 302, 12RC, WC-2430A spoolgunSpectrum 2050Thermal Arc Plasma Welder PS-3000/WC-100B
Reply:Keep in mind this is a cheap Homier Drill, I'm pretty sure the arbor of the pully assembly is machined to directly accept the chuck.
Reply:I have never seen a drill press with out a jacobs taper (JT) even the cheap chinese imports.  It is because every chuck mfg uses JT.  I also recommend spending the $40-60 on a good Jacobs chuck (get the ball bearing type) even a cheap drill press runs better with a good chuck.Ron ShopFloorTalk Millermatic 350P, M-25, M-40 gunsDynasty 300DX, Coolmate 3, Crafter CS-310 TorchTrailblazer 302, 12RC, WC-2430A spoolgunSpectrum 2050Thermal Arc Plasma Welder PS-3000/WC-100B
Reply:I'll give it the once over and see if it has a slot for a drift. If not I'm guessing the pickle fork might work to remove it. And for sure a new chuck this one bites... the one jaw the top thread was not formed correctly and that allowed it to fall out of the chuck. Go figure.
Reply:Here are the wedges:http://www.jlindustrial.com/search/s...equestid=17645And the chucks:http://www.jlindustrial.com/search/s...equestid=17662J&L is not the cheapest but it gives you an idea.  If you have a machinery's handbook you can determine what the taper is and narrow your search.Ron ShopFloorTalk Millermatic 350P, M-25, M-40 gunsDynasty 300DX, Coolmate 3, Crafter CS-310 TorchTrailblazer 302, 12RC, WC-2430A spoolgunSpectrum 2050Thermal Arc Plasma Welder PS-3000/WC-100B
Reply:Move the table off to the side, and run the spindle part way down, and have somebody hold the handle for you.Slide the pickle fork onto the shaft behind the chuck, and give the shaft side of the fork a good sharp whack with a hammer.  That ought to have the chuck off quick.Appreciation Gains You Recognition-
Reply:Hehehe, ran out to the shop and pulled it apart with the pickle fork...practically fell off. Seems to be a 5/8" shaft. The chuck itself says 1.5-13mm B16.
Reply:Is B16 the taper?
Reply:Got one on order should be here middle of the week. Thanks for the help guys!!!!
Reply:Cool.  What taper did it end up being?I'm thinking of getting some morse tapers for my clarke, just to mess around.  Maybe a drill socket for a really big twist drill, that'd be fun.
Reply:Good job Hobweld. The new chuck will make it a nice drill press. By the way, the way I got my chuck off was by tapping the side with a wooden mallet. It dropped off easily.I can't remember the taper, but I think is might have been a Jacobs Taper #2.Here is a site that shows how to measure the Jacobs and Morse tapers.http://www.newmantools.com/tech/taper.htmMM175Lincoln AC225 Tombstone
Reply:Here's a previous post that answers questions about "Morse tapers" on drill presses.http://www.weldingweb.com/vbb/showthread...ht=morse+taper
Reply:B16 turned out to be the taper type. Not sure if that is morse or jacobs. Would be good to know. Will do a little searching to see if I can find out. Thanks again.
Reply:Guess the B16 designation is a Metric taper.
Reply:Received the new chuck from Grizzly friday. Installed it without a hitch and all is right with the world once more.  Actually the new chuck is twice the weight and size of the old one definately better made. Thanks for all the help gentlemen!
Reply:what particular one did you get?StangnetShop Full Of Stuff. Joey
Reply:1/32 - 1/2 B16 was 5.96 and 6.95 s&h...hehehe go figure. It was a closeout  deal. Works great though.
GMT+8, 2025-12-28 06:03 , Processed in 0.105746 second(s), 18 queries .
