Hypertherm 45 plasma cutter torch lead rewiring.
发表于 2021-8-31 16:58:37 | 显示全部楼层 |阅读模式
Hi I have a hypertherm 45 plasma and was wondering if the torch lead can be shortened due to a small burn on it that burnt 2 wires in it? The burn is about 6 inches away from the torch head.
Reply:Just repair the wires. Cut the outer casing about 2" or so on both sides of the burnt spot repair the wires and tape it up with 3m electric tape. Or you can send it to me and I can shorten it for about $200 + shipping.www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:I would use scott #88 tape or care fully remove torch head and slide self sealing heat shrink tubeing  after taping up any damaged wires. If you disassemble the torch handle, remove the consumables first. Pip switch can be damaged if left in place when handle is taken apart.
GMT+8, 2025-12-18 16:29 , Processed in 0.091446 second(s), 18 queries .
