Is this a good welder to learn on
发表于 2021-8-31 23:08:57 | 显示全部楼层 |阅读模式
Model:The PowerArc 140 ST from Everlast is a perfect choice for the customer who has a farm, home shop or even a small fabrication business. This is the unit to have while you are out on the trail, at the track or just in your shop doing everyday fabrication chores. In fact, you can say goodbye to heavy transformer welder sitting in the corner. The dual-voltage IGBT inverter design allows the unit to go anywhere, and operate off of any standard power outlet. Maximum amp output operating on 240V is 140 amps for TIG and Stick. The amp output while operating on 120V is 87 (+- 3) amps for stick and 95(+-3) amps for TIG. The PowerArc 140ST will weld almost any metal except for aluminum and magnesium with its stick or lift-arc TIG feature. The PowerArc 140 ST comes with about everything you need to weld, including a convenient carry case (except TIG regulator and Tungsten). The stick and a standard 17 series gas-valve TIG torch, along with the work clamp are included as part of the welder package. Included also is a small starter kit of consumables for TIG. Nothing needs to be changed internally to go between 240V and 120V operation. The unit performs equally well in either stick or TIG mode. The unit can weld electrodes from 1/16 in. up to 1/8 in. thick in stick mode, and can weld up to 3/16 in. plate metal in a single pass. E6011, E6013, E7014 and E7018 stick welding rods (electrodes) all weld easily due to the automatic hot start and adaptive arc force control.Sent from my SM-N900T using Tapatalk
Reply:Very good machine to learn on.... Low cost, simple design....Do you have all the other accessories?? Bottle, tungsten, filler rods etc?????Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:All I have now is my mig n argon nothing else Sent from my SM-N900T using Tapatalk
Reply:Well,You've got to get an 100% argon bottle, bigger the better... Figure $200-$300....Tungsten, extra torch parts etc, and filler rods....run you another $100-$150...Have you ever tigged before???Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:No tig some stick and mostly mig.  Just want to keep learning honestly should a hobbiest get into tig or stick with mig and stick I'm so now to all of this and very inexperiencedSent from my SM-N900T using Tapatalk
Reply:Well,Should a guy buy a tig???That is a question that has baffled weldors for yrs....What kind of stuff do you weld on???In shop??Clean metal??Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:I love the idea of welding.  I haven't welded much honestly in the future I see a simple fire pit and end tables.  Other then that art type welding, small stuff Sent from my SM-N900T using Tapatalk
Reply:Mig will handle most anything like your talking....Tig, well, If you've never used it, you'll have a long learning curve....Watch a bunch of these video's, they'll give you lots of good tips....http://welding-tv.com/category/tig-welding/Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Would mig cover most of my stick applications also? Sent from my SM-N900T using Tapatalk
Reply:Not in a 110v powered machine..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:I have a 220 Lincoln mig welder.  Sent from my SM-N900T using Tapatalk
Reply:Originally Posted by newbe1977I have a 220 Lincoln mig welder.  Sent from my SM-N900T using Tapatalk
Reply:I have no need for tig honestly the more I think of it the more I realize it.  I should probably improve my mig before anything else Sent from my SM-N900T using Tapatalk
Reply:Practice Practice Practice....Get some pictures of your mig welds up, and we'll try and give you some helpful advice....Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Here's a couple welds from my fire pit project this morn.  Not sure how well u can see them.  A lot of crackling Sent from my SM-N900T using Tapatalk
Reply:You need to turn that machine up.Full power, with little ossilation and a steady push...
Reply:It was 16 Guage metal and was blowing thru Sent from my SM-N900T using Tapatalk
Reply:Originally Posted by newbe1977It was 16 Guage metal and was blowing thru Sent from my SM-N900T using Tapatalk
Reply:Thanks for the puctures my welder is the Lincoln hd model so sometimes I find it hard to set hopefully with more time on it I will get better.  I need to find somewhere to get affordable scrap to practice Sent from my SM-N900T using Tapatalk
Reply:Go to your local welding shop, and ask about their scrap metal dumpster...Sheet metal shops have tons of it....Is there a chart of recommended settings on your welders door???What model is it??BTW,Those welds of mine were on the 1/8 steel settings....Hot and fast....
Reply:It's the 180 hdSent from my SM-N900T using Tapatalk
Reply:You should be able to turn that machine down nice and low....Mess with it on some scrap....What size wire you using??
Reply:I was using .025Sent from my SM-N900T using Tapatalk
Reply:Originally Posted by newbe1977I was using .025Sent from my SM-N900T using Tapatalk
Reply:I just got the Everlast 140st too. Never welded before and plan to teach myself stick first and maybe try tig later if I have a big enough project. Do recycling/scrap yards generally sell their scrap to the public? There's a place near me that buys scrap. Maybe I can just sit in front and buy from people before they go in.Using TapatalkArc length& torch angle is a very important part of proper mig welding. Even with the settings "perfect" you can have a hard time. Pushing or pulling the bead is fine with the right technique. Like stated above, watch Jody's videos on welding tips n tricks. What kind of gas is your mig gas ? What kind of wire are you using?Thermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:The scrap yard is great if you're getting a piece with the right shapes and features you can't form at home, (like the SS beer keg I bought last week), the back door of a metal shop might have cleaner pieces, less paint and rust is better for practice. A new TIG, if you can afford it, will improve your eye for MIG and stick too, go for it.SqWave 200Millermatic 190Airco 200 ACHypertherm PM45Boice-Crane Band SawVictor O/A
Reply:Ordered the welder pretty excited to learn tig and practice stick.  Now need a bottle Sent from my SM-N900T using Tapatalk
GMT+8, 2025-12-28 06:04 , Processed in 0.085992 second(s), 18 queries .
