Playing with finishes
发表于 2021-8-31 23:08:49 | 显示全部楼层 |阅读模式
Hi all,seems like I am always looking for good finish ideas.  Here is a little piece of 18g scrap.  I took one end, and used some copper Insta-rust, the lighter end is where I heated the steel to a red glow, then brushed it with a brass bristle brush.  I clear-coated it to see how it holds up before I do it on a project.  I like both finishes, but the heat & brass finish would be a lot of work for a large project. Check out my channel https://www.youtube.com/channel/UCkz...bZg8AYNXGqBjZQ"Both oligarch and tyrant mistrust the people, and therefore deprive them of arms." - Aristotle
Reply:Here are a couple I've used. The beak is the heat & brass brush, neck is simply polished and the body is a cold gun blue.If you don't want to stand behind our Troops, feel free to stand in front of them.
Reply:I like the gun bluing.Check out my channel https://www.youtube.com/channel/UCkz...bZg8AYNXGqBjZQ"Both oligarch and tyrant mistrust the people, and therefore deprive them of arms." - Aristotle
Reply:The eagle got 2 coats and is quite a bit darker than the truck that only got 1. It does leave a nice finish and doesn't hide the metal.If you don't want to stand behind our Troops, feel free to stand in front of them.
GMT+8, 2025-12-28 06:04 , Processed in 0.244266 second(s), 18 queries .
