i dont have a camera capable of the resolution to get a good look at the weld.....but you get the idea. 2mm washer welded to a diffuser. Mild steel. Attached Images
Reply:Trick to get a better pict of the weld is to back up a distance, then use the zoom to get up closer. Also shoot at the highest resolution possible, then you can crop and then resize in editing to "zoom" in even more and still keep the details.Pict looks like the camera's auto focus locked in on the back ground vs the objects up front. You might check and see if the camera has a macro setting that lets the camera focus on closer items instead..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:My teacher if you will, breaks a tape measure in two and then welds it back together regularly. Thats impressive. So's the washer actually. |
