What size and thickness of tubing do you use for receiver hitches?Thank you
Reply:Female would be receiver tubing sold by the foot at your local steel yard. Basic difference between receiver tube and regular square tube is the lack of an inner seam on the receiver tubing. Pricier than regular square tube, but well worth it is you've ever tried broaching the seam out of a section of regular square tube. Male can be whatever fits the receiver tubing and meets the demand(s) of your load.Lincoln PrecisionTig 275Miller 251Miller DialArc 250Bridgeport millHossfeld bender & diesLogan shaperJet 14 X 40 latheSouth Bend 9" 'C'Hypertherm 900Ellis 3000 band saw21"Royersford ExcelsiorTwo shops, still too many tools.
Reply:http://www.harborfreight.com/18-long-2-standard-receiver-tube-69815.html is what I have used on my bench to mount a vice and/or reloading presses. I believe in overbuilding stuff, so I would probably couple that with 2x2 square tube with .25" wall thickness. If you plan on using a hitch for anything heavy or even to travel on road, I would BUY a complete setup from Curt, Reese, etc to limit my personal and legal liability if anything should fail.Have fun with whatever you are building!Harbor Freight Inverter 130 amp DC stick/tig (sold, really!)Lincoln Square Wave Tig 175 AC/DC stick/Tig
Reply:Princess Auto, here in Canada sell the standard 2" inside,seamless tube, with 5/8" hole and wrapped end for $10.00 for 10" long, $30.00 for 20" long. It's usually 2.5 outside,and .188 wall thickness.
Reply:CraboHitch Receiver tube is the only atypically sized tube in the book. It is not 2.5 x 2.5 x .250 wall.HR is - 2.530 x 2.530 x .250 wall. The interior bead removed with cutting broach drawn through the tube.This gives a split .030 clearance between the stinger and the receiver.It is a stock item at your regional steel-yard, and general-welding/machine-shops should have it by the foot.DOT approved. Opus
Reply:Originally Posted by OPUS FERROCraboHitch Receiver tube is the only atypically sized tube in the book. It is not 2.5 x 2.5 x .250 wall.HR is - 2.530 x 2.530 x .250 wall. The interior bead removed with cutting broach drawn through the tube.This gives a split .030 clearance between the stinger and the receiver.It is a stock item at your regional steel-yard, and general-welding/machine-shops should have it by the foot.DOT approved. Opus
Reply:Originally Posted by AZ-BenHave fun with whatever you are building!If you plan on using a hitch for anything heavy or even to travel on road, I would BUY a complete setup from Curt, Reese, etc to limit my personal and legal liability if anything should fail.
Reply:Originally Posted by CraboI really like the idea of the receiver mounted tools on a welding table. We are going to build a couple of 4x8 tables for school and I want to have the receivers on them. The other thing is that I want to put a hitch on my wife's flatbed Ford F450. I will be searching the archives for bumper ideas. I will also check into the complete hitch setup.She hauls bee hives on her truck. I also need to extend the headache rack up another 18" for when she is moving her bees. I am thinking about using receiver hitch materials, to mount it on top of the existing rack. Just drop it in the receivers when you need it taller, or store in between the cab and rack, in another set of receivers, for when you don't need it.
Reply:i'm with AZ-Ben, Hf works for me too! They have a 25% off coupon that is in sundays Chicago tribune. Saving money always helps !
Reply:Originally Posted by BrianCPrincess Auto, here in Canada sell the standard 2" inside,seamless tube, with 5/8" hole and wrapped end for $10.00 for 10" long, $30.00 for 20" long. It's usually 2.5 outside,and .188 wall thickness. |
