Welding table's
发表于 2021-8-31 23:08:45 | 显示全部楼层 |阅读模式
Just wondering what your using for a table? I am a using a 4'x4' table that has been morphing over the years. It is currently made of wood with the exception  of a 1/4" 4'x4' plate on the top. Once I have a design I am pleased with I will go buy the material to have it all steel. Anyone have pics? I am interested in some ideas. here is my table:I have locking good quality casters on each corner. 10ga 15' extension cord wired to a duplex box under the top. 12 plug power bar on the side with a bar to hold my grinder(s)8"x1" flat bar welded to the edge of the top for my ground clap Attached Images
Reply:Here's a pic of mine - I've since removed the sides. Made from 1.5" tube and 22ga sheet. The spider web doors are 1/2" tube and 1/4" round Attached ImagesFire!, Fire! Oh wait, that's my torch...Lincoln PT-225 TIGLincoln 175 MIG
Reply:Hay Vipernut,How about some shots of that roll   That looks like one I can make!Me!
Reply:is wood good for a welding table? jus my 2 cents worth looks great g
Reply:Obviously, there will always be a potential FIRE hazard  from the wood . At least be always concious of that fact, at ALL times. Try not to put too much heat into that top plate.[SIZE="5"Yardbird"
Reply:Well I dont cut on the top so it never gets hot. When Obviously the wood is a concern but what do you guys do to your top to get it hot enough to burn the wood? I rarely tack anything to the top."I'm really easy to get along with once you people learn to see it my way.""I'll try being nicer if you'll try being smarter."
Reply:This one is still my favorite, the top is blanchard ground 1" plate, very flat.2x4 square tube for the legs. The top weighed about 1000 lbs. maybe overkill but this table will be around forever
Reply:Originally Posted by BurnitThis one is still my favorite, the top is blanchard ground 1" plate, very flat.2x4 square tube for the legs. The top weighed about 1000 lbs. maybe overkill but this table will be around forever
Reply:Catching the wood on fire was something I thought of too when I saw the pics.   Definitely want to re-make that out of steel instead.   Yes, it will get hot.   I got my rotating jig hot enough to warp the 1" plate the other day.   If there had been wood under, it probly would have started smoldering.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Here's a pic of my do everything including welding bench, 1/4" top 11.5" long, the flamed up backsplash is aluminum. If you don't want to stand behind our Troops, feel free to stand in front of them.
Reply:nice table SWells. i would never get any thing done with that TV
Reply:I like Swells table and shop, I bet it gets a lot of use with the winters being longer and colder up there.
Reply:Alfred, the TV's not the only distraction. Inside the black cabinet is the stereo and an old notebook with wireless internet, I have everything running through the stereo (PC, TV, CD, Radio).MrRodeoCC, that's where you will find me most Friday nites.....and Saturday if the "honey do" list isn't too long.If you don't want to stand behind our Troops, feel free to stand in front of them.
Reply:the stereo i can work with and the notebook with internet is nice to have. Wow i would never leave if that was my shop but it is nice
Reply:Mine's a 3/4" 4x4' top with scrap pipe legs and surplus locking casters. It weighs about 600 lbs but moves around without too much trouble. Top is mounted on rubber pads to absorb some of the "ring" when you pound on it with a hammer.JimCut an MGB and widened 11" C4 Corvette suspension and LT1 Chevrolet power & 6 spd. Pictures here:Part 1http://forum.britishv8.org/read.php?13,7581Part 2http://forum.britishv8.org/read.php?13,22422
Reply:How tall is your table Jim?"I'm really easy to get along with once you people learn to see it my way.""I'll try being nicer if you'll try being smarter."
Reply:Here's the one I built.  Wanted something multi-functional so I added a chute (and catch can) to catch the cutting sparks.Have since added a hitch type receiver to mount additional accessories including my NoMar tire changer setup.If I had to do it over again, I'd use the 2x2 tube as one of the top supports instead of as a welded on addition.
Reply:Originally Posted by SWellsHere's a pic of my do everything including welding bench, 1/4" top 11.5" long, the flamed up backsplash is aluminum.
Reply:I had a buddy that worked at the post office mail sorting plant, that's the box the post office drops the daily bundles for the route carriers. This one was taken out of commision for some reason. Better yet, I got it for free. I've since installed the notebook on a keyboard slide out tray......right about where the scotch bottle and cigars are.If you don't want to stand behind our Troops, feel free to stand in front of them.
Reply:sweet deal and nice use of a toss away.
Reply:Originally Posted by Bryan LHow tall is your table Jim?
Reply:Cooking spray oil, wd40, any light coat of oil will help...you may want to wipe the table off with a rag soaked with thinner before you use he table though...Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Originally Posted by weldermickAlso, I'm wondering how you guys prevent your welding table tops rusting?Built this one about a year or so ago.  Wish I would have made it shorter height wise, although it serves my purposes, I like welding lower down for some reason (I learned this after using someone elses setup on their table.)  I did add on to it, and put a new rack onto it.  Haven't had time to put shelves on that and a light just yet though. Just realized I have no full pictures of it... what a fail.JoeMiller 140 Autoset (2010)Miller Syncrowave 250 (1996)
Reply:got a couple of platens tables,  several 18'x5'x1"   couple tables that are 20' 1/2" plate.    obviously they are a little more than hobby tables.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:i  got some free 6 inch channel and  i needed a bigger table so i went with it. this is what i came out with its not a grade a perfect fabrication table but it works really well for me and it was all free scrap from work. trailblazer 302 spoolmatic 25a with wc-24thermal arc 161s tig rigmillermatic 200dialarc 250 hf tig rig with spool gun and boxand wanting more......
Reply:I made my 36X54 table so it would fold up and go against the wall Attached ImagesSafety 3rdGump
Reply:It's 36" tall Attached ImagesSafety 3rdGump
Reply:Originally Posted by GumpI made my 36X54 table so it would fold up and go against the wall
Reply:Originally Posted by chevyrigi  got some free 6 inch channel and  i needed a bigger table so i went with it. this is what i came out with its not a grade a perfect fabrication table but it works really well for me and it was all free scrap from work.
Reply:To quote a famous movie, "Gump you are a #%@#*%*@ genius!"  Seriously, that thing is awesome.  I may need to copy that.  My "shop" is the garage, where the wife has this weird idea about parking her car when I am not working.  Check out my channel https://www.youtube.com/channel/UCkz...bZg8AYNXGqBjZQ"Both oligarch and tyrant mistrust the people, and therefore deprive them of arms." - Aristotle
Reply:I looked at a lot of tables and took an idea here and there and tried to have what was best for me.My TableTxDoc's Photos Lincoln SP175 PlusLincoln Power Mig 256Lincoln 250 LX Spool Gun Lincoln Precision Tig 225 Hypertherm 600 KMG 2x72 Belt GrinderBaldor 812RE Grinder
Reply:Thanks but im no genius, my table is a modified to my needs idea that i got from this site. All the pictures i have of it are in this thread. http://weldingweb.com/vbb/showthread.php?t=116421Safety 3rdGump
Reply:I am going to build a couple of tables for school. I spent a bunch of time reading posts on tables. Here are some of the best links for me.High School http://weldingweb.com/vbb/showthread.php...+welding+tablehttp://weldingweb.com/vbb/showthread.php...=welding+table (trailer hitch Acces)Holes and clamps http://weldingweb.com/vbb/showthread.php?t=67821Hitch Accessories http://weldingweb.com/vbb/showthread.php?t=108281Skateboard Wheels http://weldingweb.com/vbb/showthread.php?t=62615Slots, wheels and feet http://weldingweb.com/vbb/showthread.php...=welding+table (good feet)Miller table http://www.millerwelds.com/interests...welding-table/Mag Drill http://weldingweb.com/vbb/showthread.php...=welding+tableadjustable small http://www.cojeeps.net/showthread.ph...plans-and-picshttp://www.lincolnelectric.com/en-us...le-detail.aspx
Reply:Originally Posted by TxDocI looked at a lot of tables and took an idea here and there and tried to have what was best for me.My Table
Reply:No pics right now, but I'm currently using a 4 X 8 food piece of 2" thick Hardox 400 sitting on some 4 inch drill steel legs----------simple yet effective!6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
Reply:Originally Posted by Randall_HGot a pic of it turned right side up?
Reply:Here is one of my welding tables...  5 foot by 10 foot 1 and 1/4 thick.  On a hydraulic cylinder to lift it from the floor to  foot high[IMG][/IMG].From the desk of Kevin CaronTrying to be the best me I can!www.kevincaron.comAHP Alpha Tig 200x MillerMatic 251Miller Syncrowave 200
Reply:I like the magnetic mig gun holder. Just curious as to how you made it?Ain't No Body Got Time For That!Millermatic 211 MVPLincoln 135Strong Desire To Learn!
Reply:Sidney, I got mine from Home Depot.     Not sure who you are talking about.....From the desk of Kevin CaronTrying to be the best me I can!www.kevincaron.comAHP Alpha Tig 200x MillerMatic 251Miller Syncrowave 200
Reply:Dont pay any attention to the junk on the table but here is the top of minetrailblazer 302 spoolmatic 25a with wc-24thermal arc 161s tig rigmillermatic 200dialarc 250 hf tig rig with spool gun and boxand wanting more......
GMT+8, 2025-12-28 04:03 , Processed in 0.258034 second(s), 18 queries .
