flapwheels
发表于 2021-8-31 23:08:43 | 显示全部楼层 |阅读模式
what flapwheels are you guys using??, i picked some smelly hf ones, did a good job but didn't last long, i was thinking of trying norton's zirconia grit, anybody used those??StangnetShop Full Of Stuff. Joey
Reply:I've used a lot of different ones, and they all seem more affected by what I'm whizzing off than anything. grease, paint, varnish clog them up.  I love the fiinish I get on metal with them-its almost like chrome!   I then just clear coat it.  The ones I bought on eBay (10 for $20.00, or something like that) are as good as the others.  I also have had good results with Black & Decker from Wal Mart.  The 4 1/2" ones are a LOT better than the 4" ones.  I use them for a lot of operations I used to use a grinder on-like prepping joints to weld.  Gets 'em clean quick, and its easier to control how much metal I remove-especially important on sheet metal.At the Lake
Reply:Nortons good. If nothing else check your local Ace hardware. Some have them some don't. I don't buy any cutting wheels, grinding wheels, wire wheels, stones or anything that is going to be run at high rpm or extreme duty from Harbor Freight. HF grinding wheels disappear in a flash, wire wheels fly apart into a million daggers and the job doesn't get done.It also seems like no-ones real coarse grit flap discks holds up. Just too heavy to get to stick I guess. About 60 is as coarse as I go in the flap. 60's and 80's is all I get for raw iron."The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:I prefer the Walter brand discs with the orange plastic backing.  You can trim the plastic off the back to keep the edge flexible.  The idea is to rest the spinning disc back against the sharp corner of a bench.  The soft plastic can be cut away.
Reply:Lotech, got an online store link??StangnetShop Full Of Stuff. Joey
Reply:www.jwalterinc.comhq right next door to memy local welding supply vendor carries em, i think they were $70 for a ten pack.  less than what i would pay than if i bought dewalt's from lowes, but yikes! ill prob buy a couple next time im in there to try em out.
Reply:thanks, i'll give them a tryStangnetShop Full Of Stuff. Joey
Reply:I've always had good luck with the 4.5" Black & Decker flap disks I get from Wal-Mart.  They seem to be just as good as the DeWalts, but a lot cheaper.  Haven't used too many other brands though.  May need to pay my local Ace Hardware a visit.
Reply:^^ i have a b&d disc on mine now, i wish they sold them in a bulk pack thoughStangnetShop Full Of Stuff. Joey
GMT+8, 2025-12-28 04:11 , Processed in 0.197803 second(s), 18 queries .
