looking for grinding attachment for 1/2" drill
发表于 2021-8-31 23:08:39 | 显示全部楼层 |阅读模式
I need to grind some metal in a tight space, a 1/2" drill attachment (w/abrasive grinder like you see on a 4" grinder) is the only solution.Except, I don't see such a thing in hardware stores.  Is there such a thing?  I see those "stone" things that can be attached to a drill, but I don't know if it'll work
Reply:Sounds like you just want to attach an angle grinder type wheel to the end of a 1/2" drill?  You should be able to find an arbor for your drill that you could use to screw on a standard  angle grinding disk.  I've done a similar thing to attach the angle grinder style flap disks to my HF air tools (not running them at full speed).  Works fine for me, just had to fab a little spacer to make up for the difference between the arbor shaft and the disk hole.  Be careful and keep a good grip on the tool when you run in these non-standard configurations.  They usually handle differently in operation and you don't have the standard safety guards in place.  Good luck.TinkerTinkerCentury 135GS, ThermalArc 250GTS
Reply:http://www.mcmaster.com/asp/loadpage...ve+Disc+Arborsscroll down a littlehttp://www.mcmaster.com/asp/loadpage...brasive+Wheelssee if that worksStangnetShop Full Of Stuff. Joey
GMT+8, 2025-12-28 04:11 , Processed in 0.172966 second(s), 18 queries .
