6g tig root run
发表于 2021-8-31 23:08:32 | 显示全部楼层 |阅读模式
Hey, I'm doing my certification for 6G. I'm doing Tig root run and a full with E7018 low hydrogen with a capping with E7018. Problem is when I do the root run I'm not getting enough penetration with the TIG.... What are some possible causes??
Reply:Land thickness? bevel? root gap? filler rod size?What size pipe? schedual?JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:How much of the thickness of the wire are you holding inside the land? The more wire you hold inside, the more penetration you will get.Last edited by too many toys; 07-15-2012 at 02:49 PM.2008 Dodge 1Ton 2007 Lincoln 200D Pipelinerkubota with throttle controlMiller Dynasty 200dxLincoln 200 Powermigspoolgun
Reply:Land size 1.6 - 2 mm Bevel angle 60 degrees Root Gap 2mm. Pipe is 150mm with 10mm wall. Thanks heaps guys
Reply:Ohh and filler is 1.6
Reply:5/32 gap which I think is 4mm?1/8th filler37-.5 * angle on the bevelStick the rod half way through the bevel.
Reply:4mm is like .160......  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:You might have better luck with a fit up like JoeMayo says. More gap and a bigger filler wire than what you're using. Good luck.2008 Dodge 1Ton 2007 Lincoln 200D Pipelinerkubota with throttle controlMiller Dynasty 200dxLincoln 200 Powermigspoolgun
Reply:Thanx Guys!!!
Reply:Why the land?  Almost all tig root is done knife edge.  You should find lots of good articles here and Millers.   Easier to learn with larger wire...1/8 in. wire, tight 1/8 in. gap, 85-90 amps....on bottom concentrate your arc on mid to bottom of wire, feed about 3 times rate of travel until the bead you see takes on convex shape.  On top, less feed and arc motion is top of bevel, across wire, to other top, bead shape will be concave.  Sides will be variants of bottom and top.
GMT+8, 2025-12-28 06:03 , Processed in 0.284944 second(s), 18 queries .
