Argon anyone?
发表于 2021-8-31 23:08:19 | 显示全部楼层 |阅读模式
Someone called and said a lab was closing down and had an argon tank they wanted hauled off. I said OK, but it's a bit larger than I expected.It's about 2/3 full.Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Too bad it wasn't the one strapped to the wall, but that big one ought to be worth something, even though it says liquid on the label.
Reply:Well now Robert, I'd say that you've got some argon there, for awhile at least. The only issue with having that is that it will "gas off" continuously until either you've used it up or it's vented itself out. So get to welding brother. Also, the dwar bottle might be a lease unit and need to be returned "or". Nice score in any case. Best regards, Allanaevald
Reply:We worked a deal on the two helium tanks too. They are the UHP variety. ( ultra high purity ). Empty Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Originally Posted by copeToo bad it wasn't the one strapped to the wall, but that big one ought to be worth something, even though it says liquid on the label.
Reply:The mechanical company I used to work for did pipe freezing with liquid nitrogen in those same tanks.When you empty it out this week let us know the look on the Airgas guys face when you set it on the counter fo be filledSent from my GT-P3113 using TapatalkTOO MANY TOOLS & NO MORE SPACE
Reply:Very high probablilty that liquid cylinder belongs to some gas supplier in the area.  Usually a label on there somewhereExperience is something you get right after you need it
Reply:Did they throw in the cart?TOO MANY TOOLS & NO MORE SPACE
GMT+8, 2025-12-28 06:03 , Processed in 0.307535 second(s), 18 queries .
