My Pipe Coper
发表于 2021-8-31 23:08:13 | 显示全部楼层 |阅读模式
Built this for my rail shop.Copied the Mittler Bros. layout - cuts dead center - turned out to be way more accurate than I need for building handrail.One problem: the adjustment screws on the crossfeed ways back out when in use. Since they are supposed to be adjustable, is there a better solution to this problem than just using Locktite? Attached Images
Reply:distort one of the threads with a punch to add friction.miller thunderbolt 250vlincoln square wave tig 175 prolincoln idealarc mig sp250everlast tig 210EXTeverlast power plasma 50chicago electric (hf) 130 tig/90 arcchicago electric 90 amp flux wire3 sets oxy/acet
Reply:add a jam nut.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Thanks.I'll try these ideas.
Reply:ingenious!
Reply:Where did you get the collar to adapt from your shaft to the end mill?  Looking through catalogs I have I cant find anything that would work.
Reply:Nice! Do you have more pics? I see the motor is sideways tot he pullies, must be a gear reduction in there?
Reply:Great idea and beautiful execution. Thanks for sharing. Originally Posted by Comp ChassisWhere did you get the collar to adapt from your shaft to the end mill?  Looking through catalogs I have I cant find anything that would work.
Reply:great work! saves you $4500 on a new one
Reply:That's badass. What's the output RPM of that gearbox and the HP rating?I've seen vids of these in action but I'd still like to see a video of this if you have one.Welding/Fab Pics: www.UtahWeld.com
Reply:Neat design i was thinking about making one like the TubeShark Kotcher out of a hougen slugger and some linear bearings, but its still in the though phase.I forgot how to change this.
Reply:the hogen broaches dont really side cut worth a crapVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Great looking machine would really be handy for making gates or railings with round tubing.Please add some more pictures and even a video of the machine working.Good Luck and Never Give UpAWS MemberLincoln Idealarc 250 AC/DCHobart Beta Mig 251Hypertherm Powermax 45Lincoln WeldanPower D10 250 ProMilwaukee PortabandEllis BandsawMiller AEAD 200LE
GMT+8, 2025-12-28 06:04 , Processed in 0.094910 second(s), 18 queries .
