查看: 2|回复: 0
1" Plasma cutters... Do they cut thin stuff nicely too?
发表于 2021-8-31 23:08:06 | 显示全部楼层 |阅读模式
I'm thinking about getting the Hypertherm  Powermax 1000 (Or another machine in this class) but want to make sure that this class of machine is still usable on small thin material as well. When cutting very thin material (1/16" for instance) does this machine do a nice job like smaller Plasma cutters do? Is there a minimum cutting speed that might be too fast for thinner material?  Would a different machine be more sutible for thiner material? I want to make sure the Hypertherm 1000 will perform well with everything below 1" thick -- am I asking for too much, or is this machine good at thin stuff too?Thanks!
Reply:turn down the power, no since in using enough to cut an inch to cut 1/16''StangnetShop Full Of Stuff. Joey
Reply:they have smaller electrodes and nozzles so you can cut thinner stuffKeep your stick on the ice
Reply:I just cut a bunch of 20ga with my Miller 2050, seemed to work well enoughwww.urkafarms.com
GMT+8, 2025-12-28 06:04 , Processed in 0.099196 second(s), 18 queries .
