Another new welding cart
发表于 2021-8-31 23:07:52 | 显示全部楼层 |阅读模式
The cart isn't finished in the picture but what I wanted to show was the axle & wheel configuration. The frame of the cart is 1 1/4" square tube salvaged from a trailer I rebuilt this spring. The tubing is welded into pretty much a square configuration that I can weld brackets to to add any equipment I want on the cart. Currently I have a mig, tig, two gas bottles and accessories to be added.What I wanted was a cart with two two larger wheels that carried 99% of the weight and the swivel wheels to keep it level. The larger wheels clamp to the bottom frame rail and can be moved to maintain the balance as equipment is changed on the cart. You can see the smaller swivel front wheel, the other swivel is under the tanks in the rear. This makes the cart very easy to move around the shop. Attached Images
Reply:Nice! Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
GMT+8, 2025-12-28 06:06 , Processed in 0.102357 second(s), 18 queries .
