Best Uphill Video I've Seen
发表于 2021-8-31 23:07:50 | 显示全部楼层 |阅读模式
This is excellent for those who want a good visual to help with uphill.  I really like the real color as opposed to the stupid "thru the lense" color.  The Viking Cam sucks BTW http://www.lincolnelectric.com/en-us...al-detail.aspx"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Thanks that was interesting, never knew of doing a third pass on a weld. Agreed that showing in colour camera its way better than most videos.
Reply:Originally Posted by R.A.D.Thanks that was interesting, never knew of doing a third pass on a weld. Agreed that showing in colour camera its way better than most videos.
Reply:A helmet with a camera and LCD screen? A remote camera that you can stick up into places your head don't fit. I'd love one please!
Reply:Originally Posted by VPTA helmet with a camera and LCD screen? A remote camera that you can stick up into places your head don't fit. I'd love one please!
Reply:Originally Posted by gto_welder01you do however many passes it takes to finish. could be 1,2,3,4,5,6....ect.
Reply:Originally Posted by forhireMe too. I imagine the future will be a video fed helmets. No eye injuries and the clarity is incredible. I wonder about depth perception? What kind of cam are they using? Check this snap from 7:46
Reply:Originally Posted by VPTThat still from the video is amazing! I don't think depth perception is totally needed to weld. Many times I have welded with a mirror and only being able to see with one eye at a time and did just fine. I would think as long as I am oriented right with the camera I could weld just fine watching a TV screen.
Reply:Originally Posted by MikeGyverAt the same time though you shouldn't weave too wide. I think I've heard 5/8" or so is as wide as you should weave on 7018.
Reply:I have heard 3 time the diameter, then 6, or 4.  Truth is that you should weave as little as possible.  There is no specifics in D1.1 (that I know of)  about weave width, but for strength, stringers are the way to go.  In my opinion he weave was way to wide for anything other then aesthetic value.Sent from my DROID3 using Tapatalk 2Jay DavisAWS-CWIC-60 Specialty Welding ContractorLoving husband, and father of two boys (
Reply:Beings the guy is an instructor, I am definitely not impressed  with the quality of the weld beads he was producing. Very inconsistant on his travel. My instructors would have never signed me off on the quality of weld he was producing.  For the root pass I was taught to use a straight travel or a very slight wiggle. He seems to be zig-zagging upward at a somewhat steep angle. After the root we'd run two overlapping stringers. Then these were covered with a weave.ESAB Migmaster 250 Hobart Ironman 230Multimatic 215TWECO Fabricator 181i & 211iHH125EZ - nice little fluxcore only unitMaxstar 150 STH - very nice
Reply:on a nyc dot test  using 5/32's rod you can weave up to 3/4 " and pass test  on an 1/8 " rod about 1/2 "  or just under    would be the weave limits for this test
Reply:He could of turned his heat up just a little bit.  The final cover pass doesn't seem smooth enough.Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
Reply:TaggedThat was the best I've seen as far as clarity, thanks."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
GMT+8, 2025-12-28 06:07 , Processed in 0.084281 second(s), 18 queries .
