Backyard 2-f
发表于 2021-8-31 23:07:48 | 显示全部楼层 |阅读模式
experimenting with my first welding machine every free afternoon to prepare for welding school in 2nd quarterit's a kawasaki brand hope it's from japan as what the stores saysi dont know if it would qualify as a fillet weld basically it's 2  anglebardoing 1/8   6013  120amp arcforce 5           6010 75 amp  arcforce  5    7018   120amp  arcforce 5confusing angles from downloaded pdfs seems to make it harder and frustrating and when i get feed up i just weld and shove the stinking rod till it touches the workmetal while sparking and  just estimate the angles instead of doing or finding the right work and travel angle. first it's 45 and then lower corner and then the upper corner any advice i appreciate cause i want to learn  experimenting on overheard weaving  2sec on each corner
Reply:The 6013 fillet looks very good.  The 6010 and 7018 look like you were hurrying a bit.  Instead of counting seconds on each side of a weave, pay attention to what the puddle is doing.  Hold each side just long enough for the liquid to flow out and tie in to the base metal.  You'll find a rhythm, but the key is watching what the puddle is doing.
GMT+8, 2025-12-28 06:15 , Processed in 0.082709 second(s), 18 queries .
