Sportsman 500 Bumpers
发表于 2021-8-31 23:07:45 | 显示全部楼层 |阅读模式
Here are some pictures of my first project. I looked around online for some ideas and came across these. It was challenging but after stepping back and admiring my work, I'm pretty sure I'm addicted! Thanks for the great info on this site and all that contribute. Cheers! Attached Images
Reply:Those are pretty BA!Some blue machinesSome red machineslots of heavy steel
Reply:Yo man sweet! Great job! I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:that looks sweet! very nice sir.mike
Reply:very nice..tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:That's totally nice. .Cracking job
Reply:Nice job..that 4wheeler is just too clean...
Reply:Beautiful job. How much weight did you add there?
Reply:WOW those are gnarly and look like they will hold up for years
Reply:It looks mean and tough, great job.
Reply:I recently picked up a Hawkeye 300, I would love the specs and drawings on that build.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Thanks everyone. @AKPolaris, Probably about 45 pounds total. I used 3/16" plate and the expanded metal is 1/8". You could probably save about 5 pounds with some thinner metal. @ThorsHammer, I found the pictures online and just eyed it the best I could but I will measure it out for you if you want it. ATV Guru makes the original so not to be a complete copy cat I changed a few things and also didn't feel like dropping 450 bucks on the set. I changed the expanded metal that was on the back bumper to match the front before I powder coated them. Cheers!Millermatic 211 Cutmaster 42
Reply:Two thumbs way up!  Very pro, very cool.  Good work.Check out my channel https://www.youtube.com/channel/UCkz...bZg8AYNXGqBjZQ"Both oligarch and tyrant mistrust the people, and therefore deprive them of arms." - Aristotle
Reply:nice! i have the exact same quad and a couple cracked bumpers... i am thinking ill have to do up something similar
Reply:nice !!!Adam MMorales Ranch
Reply:Looks mean and nasty, in a good wayDave ReberWadsworth Ohio
Reply:I'm sure I'd have to make some changes to get it to fit onto mine, but I would love it if you could get me some detailed measurements and drawings. PM me.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
GMT+8, 2025-12-28 06:15 , Processed in 0.134772 second(s), 18 queries .
