MIT has welding videos
发表于 2021-8-31 23:07:39 | 显示全部楼层 |阅读模式
I found this video helpful, http://techtv.mit.edu/videos/19268-welding-with-class. Others who are entry level might also. --I found these MIT videos on how to use some of the tools of the trade even more helpful, http://techtv.mit.edu/collections/ehs-videos/videos. They're certainly no substitute for hands on experience with guidance from someone who knows what they're doing however they go far exposing people like me to the basics. --So far I've had the time to watch Machine Shop 1 and Machine Shop 2. The others are most likely equally informative.--If anyone else has stumbled across educational welding videos, I'd sure love it if links were shared.MM 211Smith Tru Lite O/A set, Thanks Bob!Lincoln AC-225--But you must not change one thing, one pebble, one grain of sand, until you know what good and evil will follow on that act. The world is in balance, in Equilibrium- Ursula K. Le Guin
Reply:If you haven't already found it, check out Jody's videos at the link below - great stuff with lots of variety, techniques, projects, and reviews of equipment.http://www.weldingtipsandtricks.com/P.S. - thanks for the link to the MIT videos - they look like they will be very helpful!!
GMT+8, 2025-12-28 06:15 , Processed in 0.078096 second(s), 18 queries .
