A/C dead on my TIG
发表于 2021-8-31 23:07:23 | 显示全部楼层 |阅读模式
Guys I have a syncrowave 180sd, serial # LA251346, it is an older machine, no digital anything  just a tig stick knob with a big polarity switch in the middle. Anyway, I lost my a/c. couple little sparks and a womp here and there and thats it. It works fine on dc negative, I tried different torches, put on a new power cable to the torch, points are fine, and i'm stumped. Any clues, this machine is in a basement with horrible wooden stairs and weighs alot. Bringing it to my LWS will be a nightmare. Any help appreciated, thanks guys I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:1st thought is if the contact on the switch has an issue. If the contact for AC is burned, then it might not be actually going into AC mode. That might have happened if you didn't get it all the way into AC one time and ran it that way.Hopefully Duane or ccawgc will come along and make a few more technical suggestions..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by DSW1st thought is if the contact on the switch has an issue. If the contact for AC is burned, then it might not be actually going into AC mode. That might have happened if you didn't get it all the way into AC one time and ran it that way.Hopefully Duane or ccawgc will come along and make a few more technical suggestions.
Reply:Funny stuff Mick!  All I got is my BACKO! I got it down there with a rope and some wood, it aint coming out like that, and i'm afraid to put 2 guys plus the weight of the machine on the staircase. I'll do what I gotsta do tho bro! I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Get it out like we got my buddies mill in his basement. Roll up the carpet, cut out the floor, hoist it straight up then put everything back...I'd like to know why those guys in the video with the lift gates were bothering with that machine. Isn't the point of the lift gate to make things easy to load in the back of a truck?.No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:If duanne doesn't pipe up, I'd try posting over on the Miller board. Cruzer over there is a pretty sharp tech. I would download the manual and go through the troubleshooting section before I go any further. Bad news is that the 180SD has a bad reputation for pooching boards. You will also need to post up you S/N, so they can get the right schematic.Good Luck
Reply:"Pooching"?  You even talk like Jeff. Mike,Here's the manual http://www.millerwelds.com/om/o355a_mil.pdf for your unit based on the SN you listed in your first post and the first thing I'd check is all the PC1 board plug connections making sure to check for corroded terminals.Next I would check for continuity between PC1 RC1 pins #6 (wire #37) and #9 (wire#39) from the changeover switch S5.  Check plugs PLG4 and PLG5 in the same circuit for good contact as well.The fact it works OK on DCEN confirms SCR modules MOD1 and MOD2 are functioning so it sounds as if the machine doesn't know AC has been selected (continuity between RC1 pins #6 and #9).Mick - gotta get me one of those. MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Thank you DUANNE!!!! I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
GMT+8, 2025-12-28 06:27 , Processed in 0.082414 second(s), 18 queries .
