cheap welding square
发表于 2021-8-31 23:07:20 | 显示全部楼层 |阅读模式
Been needing this for quite some time : something vertical to clamp onto. Always need a different clamp ...So i whipped this up last night, don't know how you could call it : welding-stopping- square-third hand, kind of a poor boy version of a strong hand tool thing only cost me nothing, just a couple of hours work since i had everything i needed laying around.Almost perfectly 90° square, a bit of weight (filled with sand and capped) so it works plenty enough for me ...and it's so satisfying to build something yourself cheers Attached ImagesLast edited by uintas; 01-15-2013 at 09:01 AM.
GMT+8, 2025-12-28 06:14 , Processed in 0.117525 second(s), 18 queries .
