welding table with bowling ball
发表于 2021-8-31 23:07:20 | 显示全部楼层 |阅读模式
Found this on another site. Really cleaver. Bowling bowl and two disc brake rotors. [ame]http://www.youtube.com/watch?v=_OnF6_V28DM[/ame]
Reply:I just saw that posted on garage journal.........great idea
Reply:Good idea, however I would have the bowling ball held in place by spring pressure and just have a lever adjustment that pulled down on the lower rotor, just put your foot down on it and it would pull down enough to allow the ball to move around.Would eliminate the need for the (potentially expensive) bottle jack and eliminate the hydraulics within it as a point of failure.  Make it easier to operate as well because you'd have one pedal as opposed to two.But still, good little idea.Owner of a classic car.
Reply:Originally Posted by Johnny ChaosI just saw that posted on garage journal.........great idea
Reply:Good idea!Millermatic 252Syncrowave 200Cutmaster 42
Reply:Originally Posted by BD1Yea, that's where I saw it. Wasn't sure if site name could be posted.
Reply:Originally Posted by rlitmanI like the concept.  A car coil spring should provide ample pressure to lock the ball in place.  Ok, so you've volunteered to build it and provide plans?  As i said on the other site, 3 legs would work better than 4, if you're planning on building one.
Reply:Great Idea
GMT+8, 2025-12-28 06:26 , Processed in 0.119185 second(s), 18 queries .
