Heres a pic of my last bend test. 43 passes E 7018 105-120 ampsLast edited by jamesyarbrough; 01-10-2013 at 01:29 AM.Reason: fix
Reply:One tiny spec but almost flawless.Last edited by jamesyarbrough; 01-10-2013 at 01:32 AM.
Reply:welding projects and pictures is the thread.It is not Links to other sites where my pictures are posted.My personal pet peeve.Thank you, come again.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:I entered the thing in. I dont know why it didnt come up.Last edited by jamesyarbrough; 01-10-2013 at 01:41 AM.Reason: rude
Reply:really? wow.Ok, well, how did you attach the pictures? Were they too large? You might have to resize them to attach them. I can assist you with posting pics. Your reply was lacking in originality. Try harder next time. Be more creative.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:I was entering the img code in the img box instead of just paisting itLast edited by jamesyarbrough; 01-10-2013 at 01:44 AM.
Reply:***** you for your post. Thermal Arc 210 FabricatorHypertherm PM 45and lots of other tools the wife doesn't know about
Reply:Bend looks kickazz. I don't see any hairlines. Can you etch it?Interested in seeing an etch just for giggles.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Im down with etching em. I heard regular drano will work. Is that true?
Reply:huh, I never heard that. Now I gotta find out. I am never going to get to sleep now. Thanks.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Am I the only one wondering why there were 43 passes, or did I read that wrong?
Reply:Originally Posted by Eric NAm I the only one wondering why there were 43 passes, or did I read that wrong?
Reply:Backing plate 1/8 rod. Thanx. Yeah its 1 in cut into 3/8 strips bent on the side. Oh and the plates were 4x4 and the gap at the route opening is 1/4 inch43 is good. There were a lot of guys that failed for going over 50. But they make you count a pass even if you grind it out. Something about heat...Last edited by jamesyarbrough; 01-10-2013 at 08:43 AM.
Reply:My profession has nothing to do with welding. I have no idea what you guys are talking about nor do I have any idea what I'm looking at in the image. Can someone give a quick explanation? What is a "bend" test?
Reply:Its where you weld two plates together and bend them to check the weld. Its how you get certified
Reply:Originally Posted by herbet99My profession has nothing to do with welding. I have no idea what you guys are talking about nor do I have any idea what I'm looking at in the image. Can someone give a quick explanation? What is a "bend" test?
Reply:Interesting. I think I get it. So the strips are cut perpindiculer to the weld seam where the weld seam transverses the strip in the middle.Anyone have a picture of a failed test?Also, is the weld on the outside of the bend?Last edited by herbet99; 01-10-2013 at 11:21 AM.
Reply:Originally Posted by herbet99Anyone have a picture of a failed test?
Reply:Looks like he had some pretty bad undercut and didnt get all the slag out
Reply:He just wasn't ready for V-butt plates. Here is an overhead fillet weld he made. Attached ImagesDont pay any attention to meIm just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:So CEP where do you teach at?
Reply:Oh I don't teach, I just try to help out where I can. My working days are over!Here is the thread where I was trying to help this kid.http://weldingweb.com/vbb/showthread.php?t=174541Dont pay any attention to meIm just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Cool. Well I start intro to mig in a couple weeks. Im sure I will hit a couple walls like I did on stick... I will probably have lots of pics of crappy welds to share.....Great photos. Just goes to prove the old saying. "A picture is worth a thousand words"Trailblazer 302Hobart Stickmate AC/DCLincoln SP 135 TSmith torchSpoolmatic 30A
Reply:Hi guys if i may ask what is the best technique in overhead 4g ( open root) and 4gf( backing plate) stringer or weave cause i think i read it someware stringer will have more chance on passing a bendtest.im practicing ( overhead) at home during free time it seems i was able to do a decent ( wiil post pic) 1/8 6010 75amp rootpass on a 10mm plate with 30deg beveled angle 1/8 rootface and a flat hotpass and capping using 7018 1/8 110 amp but it's all weaving 2sec counting side to side inverted smilley weaving hot and capping and in rootpass it's smilley no counting pattern in particular just watching that keyhole and puddle. when i try using stringers in hot pass and capping all hell break loose.i tried stringers in horizontal seems i was a able to do a reasonable bead. but in 3 or 4 position it's very hard well i need to practice more
Reply:Naruto,if you are not experienced and confident with overhead SMAW then a weave technique has a high chance of having slag trapped in the toes. When I first took my test, I found it easiest to weave the root pass (making sure to burn in well on your toes) and then run stringers for everything after. All my SMAW tests were X-ray, so I made it a point to grind the toes before running my next bead. Also, grinding a small groove on the toe of each bead will make the next pass lay in there a little bit flatter!Also, i typically run 1/8 7018 at around 120-125 amps.
Reply:fsisneros im only a newbie in welding just downloading and reading free stuffs in net for about more than a week from now and just practicing at home.ok thanks for the advice 120-125amp 1/8 7018 for 2g 3g seems fine but in 4g im having difficulty maintaning it flat at 125amp 4g ( hot filler and capping pass) maybe i must adjust my travel speed.And its been almost all weaving since i learn to weld a liitle bit i found it easyer in weaving than doing stringers , thks for that x-ray advice i'll switch and practice on stringers anyway my goal is to go to a welding school in april and pass all those bending stuffs. i learned they are using miller xmt450 cc/cv multi so i hope i will be little bit ready by that time so i wont waste time and effort. And i more i ask around on that school and i heard they are not allowed to use grinders just wirewheel and cup brush so right now im practicing also using cup wirewhell only in between passes even on tie ins in openroot 6010 rootpass, but they are only using bend test.
Reply:I try to do stringers only. I mean with a 1/4" gap you have to bump the sides on the root but stringers are by far the strongest welds and easier |
