tig welder
发表于 2021-8-31 23:07:15 | 显示全部楼层 |阅读模式
Hello  folks   I have a  syncrowave  250 dx    I hardly use  but   I would like to know if is normal  to hear  argon  inside machine when pedal is depressed  , usually I wear  ear plugs   just  this morning I was in a hurry to tig  a small piece  and  did not put in ear plugs  that's when I heard the argon inside  please help.
Reply:Originally Posted by SNUNEZHello  folks   I have a  syncrowave  250 dx    I hardly use  but   I would like to know if is normal  to hear  argon  inside machine when pedal is depressed  , usually I wear  ear plugs   just  this morning I was in a hurry to tig  a small piece  and  did not put in ear plugs  that's when I heard the argon inside  please help.
Reply:There is a relay that opens and allows the argon to flow when pedal is pressed. Could that be what you are hearing? Sent from my iPhone using Tapatalk
Reply:Originally Posted by shovelonAre you sure it is not the high freq . . .
Reply:Yes, you should hear gas when you push the peddle for 15 - 20 seconds.  If you continue to hear it something is wrong.  Push the peddle slightly more and you will hear the buzzing of the HF but it should stop as soon as the peddle is released.
GMT+8, 2025-12-28 06:05 , Processed in 0.100834 second(s), 18 queries .
