Weaving Unlimited Thickness SMAW question
发表于 2021-8-31 23:07:14 | 显示全部楼层 |阅读模式
I have never done the Unlim thick test 3G with weave but have done limited thickness using stringers, and passed bends. I know with the limited thickness you can weave all the way out, but when you are doing it on the 1" thick plate when do you start to overlap your weave passes?Miller Maxstar 200 SDPiperliner #10 Gold
GMT+8, 2025-12-28 06:04 , Processed in 0.193648 second(s), 18 queries .
