Smith Regulator doing weird stuff
发表于 2021-8-31 23:07:05 | 显示全部楼层 |阅读模式
Ever seen this before? Quick fix? Or warranty exchange? By the way, it's a C25 mixture, and starting doing it just after the second bottle hookup.Miller Bobcat 250Syncrowave  200Millermatic 252Spoolmatic 30ASpectrum 625 X-TremeMaxstar 150SVictor O/A torchesDewalt angle grindersWelded on/off for over 40 years.
Reply:I would test while running a weld bead.Dynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:I had the same problem with argon regulator. I closed the bottle, then opened it again and the problem was gone. Weird anyway...
Reply:I tried that too muliple times. I even disconnected the line to the welder to see if there was something going on there. Nope. Problem still there. I tried manually regulating the main valve to vary input pressure into the regulator, and discovered it would act up at only over 1300 psi.Miller Bobcat 250Syncrowave  200Millermatic 252Spoolmatic 30ASpectrum 625 X-TremeMaxstar 150SVictor O/A torchesDewalt angle grindersWelded on/off for over 40 years.
Reply:Problem resolved. Miller sent me a new regulator and says the problem is rare. Can't believe how fast they got me the new regulator. I guess it's my reward for not falling for ultra-cheap foreign made welding equipment.Last edited by Gobysky; 08-09-2012 at 08:40 AM.Reason: clumsy fingersMiller Bobcat 250Syncrowave  200Millermatic 252Spoolmatic 30ASpectrum 625 X-TremeMaxstar 150SVictor O/A torchesDewalt angle grindersWelded on/off for over 40 years.
Reply:My TIG regulator did something similar awhile ago after getting a new bottle of argon. Didn't make noise and jump as bad but the low pressure needle would vary up and down as it flowed. Turned out I had moister/condensation in the regulator somehow. Either from the bottle of new argon or got in the regulator when it was off the bottle. After pulling the regulator apart and cleaning it all out it has worked fine again ever since.
Reply:Sounds like ya got bad gas! I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
GMT+8, 2025-12-28 06:15 , Processed in 0.137347 second(s), 18 queries .
