Here is the welding table that I have been working on.http://talk.newagtalk.com/forums/thr...29664#M2829664
Reply:Your 1st post as a link is not usually appreciated, you should do your intro then post your pics...Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Much easier to paste a link then write it all out again. Relax man! Some of us have to work in the morning! Just kidding....
Reply:Looks like purlins! And a nice clean new metal building! Great job. Is it comfortable working on a top that "open"?
Reply:You might want to consider adding receiver tubes to mount your table accessories to so they can be removed for an unobstructed table top when needed. I put one on each corner of my table so I can move things to different places as needed. I made a flat plate piece to set my chopsaw on, so the saw table is level with the table top to support stock being cut. the plate is big enough I can rotate the saw on it to make miter cuts and still keep the stock on the table. I used 2x2 tubing for mine, but you could use what ever fits the tubing on the corners of your table. The good thing about using the 2x2 tubing is the accessories can be used in a receiver hitch on your truck if you have to go mobile. Attached Images
Reply:Originally Posted by Fabn4FunLooks like purlins! And a nice clean new metal building! Great job. Is it comfortable working on a top that "open"?
Reply:Good looking table. Are you sure your shop is big enough for it??JackFort Loramie, OhioMilermatic Autoset 180
Reply:Good looking table, however, I would have made the cutting bars replaceable. The way it is setup right now, they're wear out eventually and need to be replaced which will require cutting them off and welding a new one in.--Wintermute"No man's knowledge here can go beyond his experience." - John Lockewww.improvised-engineering.comManufacturer Agnostic:Blood----------Sweat---------Tears----|------------------|----------------|----Lincoln Red, Miller Blue, Esab Yellow |
