Plasma cart
发表于 2021-8-31 23:07:00 | 显示全部楼层 |阅读模式
I dont have much room in my garage and this POWERMAX 380 is heavy so I threw this together. Also, I have some pics of a cross I made for my cats grave (FradyCat) using the plasma cutter. Hes barried next to Batch my little dog that bit a rattle snake that in return bit her and took her life. She has a rebar cross already. Theres also a duck or a copy of Clay Smith logo with teeth but no cigar I did with the coupons that I got with the Cutter.The blue strap holding the cutter is temporary as I want to use a battery hold down type holder. Its a crude cart but works and the dolly comes loose if I have to move some heavy metal for cutting. Theres also some 16 ga crc holding the table part up not shown. I tried to make the load go thru the legs but the welds are holding the load on the back end. I used 0.350 FCAW.I thought the Powermax 380 was an inverter but its way to heavy. The coils and xfmr windings can only be Copper as I mentioned its heavy. Also, Im sure everyone already knows this but, copper is heavier than   steel and Iron. Gold and Lead are the only metals that I know that are heavier than Copper. Attached Images
Reply:I ditched the little compressor. It made everything heavier than needed for speed in the garage.
GMT+8, 2025-12-28 06:05 , Processed in 0.111209 second(s), 18 queries .
