Scored a eight inch Wilton Vice
发表于 2021-8-31 23:07:00 | 显示全部楼层 |阅读模式
I picked up a 8" Wilton Vice for free but it has been abused. It was used to hold pieses of 6" flat bar while they were being preped for welding unfortunalty the vice was getting groun as much as the steel was. I am planing to build the vice back up and machine it back to original. dose anyone have any idea what filler I should use for a cast vice. Attached Images
Reply:I would think to machine it further to accept and then build a custom set of big machined jaws to bolt on. the vice itself is awesome, if machined square and done well it would be good as new functionality wisemiller 330a bp TIGmiller dynasty 200DX TIGmillermatic 185 MIGthermal dynamics cutmaster 101 plasma cuttersnap-on YA5550 plasma cutterhypertherm powermax 30 plasma cutterbaileigh CS225 cold sawetc....
Reply:Do a spark test on it.  I'm not sure if it is nodular iron or cast steel, but that's the easiest way to find out.  Whichever it is, Wilton uses good metal, and I believe that is at least 60KSI.If it is cast steel, your idea sounds workable.  If not, perhaps you could build it up with bronze, but I'm not sure how well that would work out.That poor poor vise.  Ouch.
Reply:Wilton says they use 60,000 PSI Ductile Iron for the body
Reply:Man that is one abused piece of metal!!  Be interesting to see the finished product after rebuild.  Keep us posted.  Best  Bob
Reply:All that abuse and it's still smiling. He can take a licking. (2nd pic.)
Reply:Originally Posted by skipweidnerWilton says they use 60,000 PSI Ductile Iron for the body
Reply:RlitmanMachining is not a problem I spent 30 plus years in a manufacturing enviroment I can run anyting from a drill press to a 5 axis mill after I retired I took up welding. After reading what you said I am thinking about maching replacment jaws that will locate off the business end and sides of each jaw. then brazing the new parts to the existing stumps.Thanks for the infoSkip
Reply:Originally Posted by trapperjohnAll that abuse and it's still smiling. He can take a licking. (2nd pic.)
GMT+8, 2025-12-28 06:04 , Processed in 0.072308 second(s), 18 queries .
