Gym Equip
发表于 2021-8-31 23:06:58 | 显示全部楼层 |阅读模式
Hey, just thought I'd post a couple pix of my latest projects.   The pullup bars are nice, cause they are bolted together, so if they ever wanted to take them down and store them it's pretty easy, and the holes are positioned perfectly that any piece can attach anywhere and the holes will line up.Had a problem with that weight stand though.  It was rocking pretty bad, the bottom 2x3 piece warped upwards.. I'm guessing cause of the heat when I welded it, to the upright 2x3.   So, I eventually ground off the welds flipped over the bottom 2x3 and re-welded it, now it doesn't rock and its perfect!Next time I build something like that, I should probably just clamp it down when I weld it?  Is that a common practice??Thanks,Derek Attached Images
Reply:Darn, sorry they are sideways, i dunno how to fix that!!
Reply:Originally Posted by DerekHey, just thought I'd post a couple pix of my latest projects.   The pullup bars are nice, cause they are bolted together, so if they ever wanted to take them down and store them it's pretty easy, and the holes are positioned perfectly that any piece can attach anywhere and the holes will line up.Had a problem with that weight stand though.  It was rocking pretty bad, the bottom 2x3 piece warped upwards.. I'm guessing cause of the heat when I welded it, to the upright 2x3.   So, I eventually ground off the welds flipped over the bottom 2x3 and re-welded it, now it doesn't rock and its perfect!Next time I build something like that, I should probably just clamp it down when I weld it?  Is that a common practice??Thanks,Derek
Reply:Nice.  I always ask others, so ill ask you too.... What machine and/or welding process did you use for that project?  Looks nice.Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
Reply:Hey using the miller 211... Machine is amazing!DerekMiller 211
GMT+8, 2025-12-28 06:07 , Processed in 0.103689 second(s), 18 queries .
