mounting a vise to the bench
发表于 2021-8-31 23:06:58 | 显示全部楼层 |阅读模式
you would think this would be a simple,straight forward task. i saw an older thread here featuring a couple dozen vises of all sizes and makes bolted to the corner of the bench. although that's the easiest way to do it you have to lean over the bench to work on whatever it is you're fixing. on my bench i welded a pre-drilled plate to the corner and fit a piece of pipe from the bottom of that to the floor and anchored it with a 5/8th pin. now i have access to 3 sides. i have 2 vises on my bench a small one for light jobs and a heavy duty one for the bigger projects. on the larger vise leg i welded a hook to hang the stinger. Attached ImagesLast edited by docwelder; 01-18-2013 at 08:49 PM.Reason: no picsi.u.o.e. # 15queens, ny and sunny fla
Reply:great idea on vise . but can we get a picture of the anvil stand. thanks
Reply:great idea. i like it .just pull a pin to get it out of the way, never have to unbolt the vise..
Reply:This works well but you must consider the bench is made out of 2" plate.  Dan D. Attached Images
Reply:Originally Posted by kei8masgreat idea on vise . but can we get a picture of the anvil stand. thanks
Reply:Hey doc have you seen the ones done with square receiver tubing mounted horizontal under under your bench Makes for easy swap for another tool or grinder or what ever want http://weldingweb.com/vbb/showthread.php?t=59229It would eliminate the post sticking up un less you want thatIuoe12 retiredBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:I put the hitch receiver under the edge of my table and interchange between the vise and bench grinder.                                            MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Originally Posted by killdozerd11Hey doc have you seen the ones done with square receiver tubing mounted horizontal under under your bench Makes for easy swap for another tool or grinder or what ever want http://weldingweb.com/vbb/showthread.php?t=59229It would eliminate the post sticking up un less you want thatIuoe12 retired
Reply:I  like that blacksmith helper. That's another goodie I might just have to copy !
GMT+8, 2025-12-28 06:06 , Processed in 0.074329 second(s), 18 queries .
