My freshly fabricated welding table
发表于 2021-8-31 23:06:57 | 显示全部楼层 |阅读模式
Reply:how thick is the plate on top and how is it supported? a bar welded across the narrow end would be a good place to hang c clamps.  looks good.i.u.o.e. # 15queens, ny and sunny fla
Reply:Very nice I also like the vice stand. Point reduction for shop cleanliness way to clean.Dave ReberWadsworth Ohio
Reply:Nice...and the table is way to clean...
Reply:Thanks guys, there's a 2x2 tube in the center, the long way, I have three countersunk bolts in the kibble and two on the edges on each side, I had to shim the outsides because the plate was bent in a concave shape, yes pain in the ***, the plate is 3/8 thick, painted with rustoleum royal blue and brsh stroke remover, I'm picky, the bar is a great idea as well as my next step. Thanks again. Oh, Casters are HF, great deal for $16 each
Reply:I love it.  Now I am wiping drool off my keyboard!Check out my channel https://www.youtube.com/channel/UCkz...bZg8AYNXGqBjZQ"Both oligarch and tyrant mistrust the people, and therefore deprive them of arms." - Aristotle
Reply:Nice job and I like the ''Miler blue'' color.   Now you gotta get a Miller machine. Shop is way too clean. You sure will be able to place a lot of stuff on that table. You need to load that table up. Do you have a cabinet or rolling tool cart for clamps, hammers, squares, grinders, etc. ?
Reply:that table should last you for a while. very nice work.i.u.o.e. # 15queens, ny and sunny fla
Reply:yea the hobart is my mig welder, i painted the table bue to match my syncro 250 and my diversion 180, rustleum makes a spray blue that matches miller better than this one
Reply:the table looks good.this is the one i just did. Attached Images
Reply:Grim jeeper, do those feet support all the load when stationary? they look like they'd be awfully wobbly.and Cdavid82, nice table... are those locking HF casters the 'full locking' kind that also lock the swivel?Last edited by MikeGyver; 01-20-2013 at 02:33 AM.Welding/Fab Pics: www.UtahWeld.com
Reply:looks great. im all most done with my table.
Reply:Originally Posted by ed maclooks great. im all most done with my table.
Reply:That's a very nice table grim, now u need to throw some red on there to match that Lincoln.The casters are fixed at the back and fully locking and swivel at the front
Reply:MikeGyver .. I don't actually use those legs to carry any weight.  Because my garage floor is not completely level, depending on where I have the table I can lower one or two of the legs just enough to stabilize the table .. but the main weight is carried by the castors.
GMT+8, 2025-12-28 06:04 , Processed in 0.104863 second(s), 18 queries .
