Overlay of Nickel base on the API 5L X65, Help...
发表于 2021-8-31 23:06:54 | 显示全部楼层 |阅读模式
I weld on the API X65 with Nickel consumble(N06625)  use auto-TIG(hot wire), the surface prepared clearly with machining and acetone. The parameter : 200A ,10.1V,travel speed100mm/min, feeding speed 2.0m/min,wave width 6mm,wave speed 1500mm/min,dwell time bothside0.5s, 99.99%Argen shielding flow 12L/min. During welding, I can see some flotage(colour is offwhite) on the melt metal. who know what it is?  And how to eliminate it during welding?
GMT+8, 2025-12-28 09:51 , Processed in 0.109914 second(s), 18 queries .
