Welding Stinger name help
发表于 2021-8-31 23:06:51 | 显示全部楼层 |阅读模式
What is the name of this kind of stinger I cant find one and I really want to buy one. thanksLincoln 140 Pak MIG Everlast powerarc 140 STLincoln Tombstone
Reply:Stinger V.    :http://www.stingerv.com/Last edited by Bluewelders; 06-29-2014 at 12:31 PM.
Reply:http://www.stingerv.com/products002.php
Reply:http://www.mitrowskiwelding.com/stin...ed-p-3643.html...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Thank you guys.Lincoln 140 Pak MIG Everlast powerarc 140 STLincoln Tombstone
Reply:What is the advantage??  It looks to be really nicely made but "appears" to only have the rod out the side or is it multi position??
Reply:it grips the rod really well, and you can bend the rod any direction desired.-------------------------Chemetron AC/DC 300 HFSnap-On MM300L Lincoln SP140 Lincoln AC/DC 225g Lincoln SA200 Lincoln SA200 Miller Bobcat 225GVictor torchesH&M and Mathey beveling machinesMcElroy Plastic pipe fusion
Reply:For nearly $70, it ought to pick up the rod for you!
Reply:idk how it's guaranteed to outlast any other stinger when it's not even insulated on the business end.i.u.o.e. # 15queens, ny and sunny fla
Reply:Originally Posted by docwelderidk how it's guaranteed to outlast any other stinger when it's not even insulated on the business end.
Reply:Yeah,Uninsulated is BS.You cant even set it down on your table.Only for pipelines, but if you forget and lay it down on some grounded steel....Seems crazy.Insulation wouldn't get in the way of anything...I'm a critic tho.~John
Reply:Originally Posted by copeThey make an insulated model, which begs the question, why make an uninsulated one?
Reply:Most pipeline guys ran T300 stingers for years, which are also un-insulated.  Not a big deal after you get used to them.  Lot of guys ran them both for stinger and ground.  Made it easy to switch polarity if the need arose...-------------------------Chemetron AC/DC 300 HFSnap-On MM300L Lincoln SP140 Lincoln AC/DC 225g Lincoln SA200 Lincoln SA200 Miller Bobcat 225GVictor torchesH&M and Mathey beveling machinesMcElroy Plastic pipe fusion
Reply:Originally Posted by AKweldshopYeah,Uninsulated is BS.You cant even set it down on your table.Only for pipelines, but if you forget and lay it down on some grounded steel....Seems crazy.Insulation wouldn't get in the way of anything...I'm a critic tho.~John
Reply:Originally Posted by 12V71They cool much better without the insulators and send a lot less heat back to your hand.
Reply:Originally Posted by AKweldshopWhat ever you like, I just hate it when stuff grounds out.
Reply:If you're just welding pipe (or welding pipe 99% of the time), you're not laying the stinger on anything that's grounded.  So it's not an issue.  Just from habit I guess, when I'm welding on something on the back of the truck, or on a table in the shop, I don't ever lay the stinger on anything.  I've been using just a regular Tweco stinger for quite a while now, but getting ready to order some new T300's.  One thing with the Stinger V, you can't just flick the rod butt into your rod bucket like you can with a normal style.  You pretty much have to just drop the stub out of it (so I've been told, and can see what they mean).  Otherwise, I don't think I've heard of anyone not liking them.  Just a matter of preferance.  Some people like the twist type "short stub" holder I think it's called.  Others don't... Whatever works for the individual... Just like some prefer fixed shade hood, some like auto, some use a pancake for everything.-------------------------Chemetron AC/DC 300 HFSnap-On MM300L Lincoln SP140 Lincoln AC/DC 225g Lincoln SA200 Lincoln SA200 Miller Bobcat 225GVictor torchesH&M and Mathey beveling machinesMcElroy Plastic pipe fusion
Reply:http://www.plwelder.com/store.php/pr...nger-v-plw1083Lincoln SA 200Esab Caddy 160Thermal Arc 201TSMiller Dialarc HFI don't like making plans for the day because then the word "premeditated" gets thrown around the courtroom....
Reply:I just LOVE LOVE LOVE the standard Tweco's.  They just work and cost less than half as much as a StingerVLincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
Reply:im just welding on pipe. I could just lay the stinger on the pipe stand with it dangling. Ill get insulated.Lincoln 140 Pak MIG Everlast powerarc 140 STLincoln Tombstone
Reply:So is this one insulated ?Lincoln 140 Pak MIG Everlast powerarc 140 STLincoln Tombstone
Reply:Yes it is.
Reply:For no known reason to me I never lay the stinger on metal either.I kinda think a better bite is a good idea as the last couple I tried I thought were kind of junk. I was thinking about trying a twister but I still like the idea of being able to let go of it. I might have to try one of these.
GMT+8, 2025-12-28 09:51 , Processed in 0.109415 second(s), 18 queries .
